简介
This tutorial will guide you through replacing the SSD card of a Dell Latitude 7420.
Before starting, please ensure the device is turned off and disconnected from any adaptors or charging cables.
Likewise, use an anti-static band or mat when opening computers or handling components.
你所需要的
Remove the eight, 7 mm screws from the back case using a Phillips #0 screwdriver.
Use an opening pick or opening tool and work your way around the periphery of the base cover to separate it from the chassis.
3等其他人完成本指南。
4指南评论
This is the ONLY internal storage on this laptop, right? So we need to make a Windows backup before starting?
Laura Doan - 回复
Yes it is the ONLY storage in the device. You definitely need a Windows backup. Alternatively you can reinstall Windows completely new.
