跳转到主内容
Dell Latitude 7420 Battery Replacement
你所需要的
  1. Dell Latitude 7420 Battery Replacement, Back Case: 步骤 1 中的图像 1,3 Dell Latitude 7420 Battery Replacement, Back Case: 步骤 1 中的图像 2,3 Dell Latitude 7420 Battery Replacement, Back Case: 步骤 1 中的图像 3,3
    • Remove the eight, 7 mm screws from the back case using a Phillips #0 screwdriver.
    • Use an opening pick or opening tool and work your way around the periphery of the base cover to separate it from the chassis.
  2. Dell Latitude 7420 Battery Replacement, Battery: 步骤 2 中的图像 1,2 Dell Latitude 7420 Battery Replacement, Battery: 步骤 2 中的图像 2,2
    • Be sure to use an anti-static band or mat from this point onward.
    • Using the Phillips #1 screwdriver, remove the five 5 mm screws securing the battery to the motherboard.
  3. Dell Latitude 7420 Battery Replacement: 步骤 3 中的图像 1,2 Dell Latitude 7420 Battery Replacement: 步骤 3 中的图像 2,2
    • Use a spudger to pry up each side. Then, lift the connector straight up from its socket.
    • To reinstall, carefully position the connector, and then press it straight down until it snaps into its socket. Finger pressure is all that is required. If it won't snap home it'll be because it isn't correctly positioned. Sometimes it can take a little patience to find exactly the right position.
  4. Dell Latitude 7420 Battery Replacement: 步骤 4 中的图像 1,1
    • Gently remove the battery from its housing.
结论
Xaiven Watson-torres
于02/02/23注册
97 声望
撰写一个指南
团队
Gateway, Team 1-2, Pee Spring 2023 Gateway, Team 1-2, Pee Spring 2023 的会员
GCC-PEE-S23S1G2
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 57
总计 583
