跳转到主内容
Dell Latitude 7420 Battery Replacement
你所需要的
  1. Dell Latitude 7420 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Dell Latitude 7420 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the eight 7 mm screws from the from the back panel using the Phillips #1 screwdriver.
    • Please prevent the static damage by working from anti-static mat or wearing anti-static bracelet or touch the metal with hands to discharge.
  2. Dell Latitude 7420 Battery Replacement: 步骤 2 中的图像 1,2 Dell Latitude 7420 Battery Replacement: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Slide the opening pick in between the back cover and work your way around the edges to remove the back cover from the device.
    • Do not insert the pick tweezers too deep, since it may damage the other components on the motherboard.
  3. Dell Latitude 7420 Battery Replacement: 步骤 3 中的图像 1,2 Dell Latitude 7420 Battery Replacement: 步骤 3 中的图像 2,2
    • Using the Phillips #1 screwdriver, remove the five 5 mm screws.
  4. Dell Latitude 7420 Battery Replacement: 步骤 4 中的图像 1,1
    • Disconnect the battery from the motherboard by gently pulling out the connector.
  5. Dell Latitude 7420 Battery Replacement: 步骤 5 中的图像 1,2 Dell Latitude 7420 Battery Replacement: 步骤 5 中的图像 2,2
    • Remove the battery from the laptop.
    • Before removing the battery from the laptop, please remove the cables that are attached on the battery.
结论
4等其他人完成本指南。
Hong Lee
于05/11/21注册
208 声望
撰写一个指南
团队
一条评论
Do you know if you can upgrade the battery i.e. go from 42 to 63? I noticed the voltages were different.
Andrew Violet - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 71
过去 30 天: 349
总计 10,338
