跳转到主内容
Dell Latitude 7390 SSD Replacement
你所需要的
  1. Dell Latitude 7390 SSD Replacement, Bottom Panel: 步骤 1 中的图像 1,1
    • Orient your Dell Latitude 7390 laptop so that it is facing towards you as if you're going to open it.
  2. Dell Latitude 7390 SSD Replacement: 步骤 2 中的图像 1,3 Dell Latitude 7390 SSD Replacement: 步骤 2 中的图像 2,3 Dell Latitude 7390 SSD Replacement: 步骤 2 中的图像 3,3
    • Flip your laptop over so that the bottom is facing up.
  3. Dell Latitude 7390 SSD Replacement: 步骤 3 中的图像 1,1
    • Using your Phillips #1 screwdriver, remove the eight 6 mm screws around the border of the bottom panel.
  4. Dell Latitude 7390 SSD Replacement: 步骤 4 中的图像 1,2 Dell Latitude 7390 SSD Replacement: 步骤 4 中的图像 2,2
    • Using an opening tool or picks, work your way around the periphery and pry the back case off.
  5. Dell Latitude 7390 SSD Replacement: 步骤 5 中的图像 1,1
    • Finally, lift the back panel off to uncover the inside of your Dell Latitude 7390.
  6. Dell Latitude 7390 SSD Replacement, Battery: 步骤 6 中的图像 1,1
    • Make sure the laptop is turned OFF and unplugged from the power adapter before taking the battery out.
    • Use the Phillips #1 screwdriver to remove the five 6 mm screws holding the battery in place along the edges of the battery.
  7. Dell Latitude 7390 SSD Replacement: 步骤 7 中的图像 1,3 Dell Latitude 7390 SSD Replacement: 步骤 7 中的图像 2,3 Dell Latitude 7390 SSD Replacement: 步骤 7 中的图像 3,3
    • Be careful not to break the connector by pulling too hard on the black tab.
    • Pull the black tab on the top of the connector to unplug the battery from the motherboard.
  8. Dell Latitude 7390 SSD Replacement: 步骤 8 中的图像 1,1
    • Carefully lift the battery out of the laptop.
  9. Dell Latitude 7390 SSD Replacement, Solid State Drive (SSD): 步骤 9 中的图像 1,1
    • Using a Phillips screwdriver, remove the 6 mm screw from the SSD cover.
  10. Dell Latitude 7390 SSD Replacement: 步骤 10 中的图像 1,1
    • Remove the SSD card from under the silver plate.
结论
Thomas Pryor
于02/22/22注册
86 声望
撰写一个指南
团队
Clemson, Team 1-4, Hunter Spring 2022 Clemson, Team 1-4, Hunter Spring 2022 的会员
CLEM-HUNTER-S22S1G4
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 16
过去 30 天: 64
总计 2,965
