跳转到主内容
Dell Latitude 7390 Battery Replacement
你所需要的
  1. Dell Latitude 7390 Battery Replacement, Bottom Panel: 步骤 1 中的图像 1,1
    • Orient your Dell Latitude 7390 laptop so that it is facing towards you as if you're going to open it.
  2. Dell Latitude 7390 Battery Replacement: 步骤 2 中的图像 1,3 Dell Latitude 7390 Battery Replacement: 步骤 2 中的图像 2,3 Dell Latitude 7390 Battery Replacement: 步骤 2 中的图像 3,3
    • Flip your laptop over so that the bottom is facing up.
  3. Dell Latitude 7390 Battery Replacement: 步骤 3 中的图像 1,1
    • Using your Phillips #1 screwdriver, remove the eight 6 mm screws around the border of the bottom panel.
  4. Dell Latitude 7390 Battery Replacement: 步骤 4 中的图像 1,2 Dell Latitude 7390 Battery Replacement: 步骤 4 中的图像 2,2
    • Using an opening tool or picks, work your way around the periphery and pry the back case off.
  5. Dell Latitude 7390 Battery Replacement: 步骤 5 中的图像 1,1
    • Finally, lift the back panel off to uncover the inside of your Dell Latitude 7390.
  6. Dell Latitude 7390 Battery Replacement, Battery: 步骤 6 中的图像 1,1
    • Make sure the laptop is turned OFF and unplugged from the power adapter before taking the battery out.
    • Use the Phillips #1 screwdriver to remove the five 6 mm screws holding the battery in place along the edges of the battery.
  7. Dell Latitude 7390 Battery Replacement: 步骤 7 中的图像 1,3 Dell Latitude 7390 Battery Replacement: 步骤 7 中的图像 2,3 Dell Latitude 7390 Battery Replacement: 步骤 7 中的图像 3,3
    • Be careful not to break the connector by pulling too hard on the black tab.
    • Pull the black tab on the top of the connector to unplug the battery from the motherboard.
  8. Dell Latitude 7390 Battery Replacement: 步骤 8 中的图像 1,1
    • Carefully lift the battery out of the laptop.
结论
To reassemble your device, follow these instructions in reverse order with your replacement battery.
4等其他人完成本指南。
Julia Blahut
于02/22/22注册
303 声望
创作了2篇指南
团队
Clemson, Team 1-4, Hunter Spring 2022 Clemson, Team 1-4, Hunter Spring 2022 的会员
CLEM-HUNTER-S22S1G4
5 名成员
创作了7篇指南
2条评论
Are there any videos for the 7390 with the smaller battery (42Wh) versus the larger one?
Kitty Kang - 回复
It would be super helpful if the laptop was named correctly as the "Latitude 7390 2-in-1" and if the title and introduction of this article also named it as such. That is the one shown here and for which ifixit guides exist. The Latitude 7390 is the non-convertible version, its inside is slightly different compared to the one shown here and so far no guides exist as far as I'm aware.
Almariel - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 44
过去 30 天: 201
总计 9,556
