简介
If your laptop battery fails or no longer holds a sufficient charge you can easily replace it. This guide will advise you on how to replace the battery.
你所需要的
步骤 1 Lower Case
注意:步骤 1-2 源自标记为进行中的 指南。
Remove the following ten T5 screws securing the lower case to the upper case.
Two will be 6mm, eight will be 3mm in length.
即将完成!
结论
2等其他人完成本指南。
