你所需要的
Remove the battery, SD card & base cover from the computer, respectively.
Pry the securing clips away from the memory module until it pops up. Remove the memory module from its connector on the system board.
Insert the memory module into the memory socket.
Press the memory module down until it clicks into place.
Install the base cover, SD card, & battery on the computer, respectively.
即将完成!
结论
