跳转到主内容
Dell Latitude 5480 Speakers Replacement
你所需要的
  1. Dell Latitude 5480 Speakers Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Use a Phillips screwdriver to remove the eight 5.6 mm screws that secure the lower case.
  2. Dell Latitude 5480 Speakers Replacement: 步骤 2 中的图像 1,3 Dell Latitude 5480 Speakers Replacement: 步骤 2 中的图像 2,3 Dell Latitude 5480 Speakers Replacement: 步骤 2 中的图像 3,3
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry up around the perimeter of the device until the lower case fully releases.
    • Lift off the lower case.
  3. Dell Latitude 5480 Speakers Replacement, Battery: 步骤 3 中的图像 1,2 Dell Latitude 5480 Speakers Replacement, Battery: 步骤 3 中的图像 2,2
    • Remove the four 5.6 mm Phillips screws that secure the battery.
  4. Dell Latitude 5480 Speakers Replacement: 步骤 4 中的图像 1,3 Dell Latitude 5480 Speakers Replacement: 步骤 4 中的图像 2,3 Dell Latitude 5480 Speakers Replacement: 步骤 4 中的图像 3,3
    • Lift the battery up and out of the chassis.
  5. Dell Latitude 5480 Speakers Replacement, Dell Latitude 5480 Battery Disconnection: 步骤 5 中的图像 1,2 Dell Latitude 5480 Speakers Replacement, Dell Latitude 5480 Battery Disconnection: 步骤 5 中的图像 2,2
    • Grip the black battery cable connector loop and pull it directly up to disconnect the battery.
  6. Dell Latitude 5480 Speakers Replacement, Speakers: 步骤 6 中的图像 1,3 Dell Latitude 5480 Speakers Replacement, Speakers: 步骤 6 中的图像 2,3 Dell Latitude 5480 Speakers Replacement, Speakers: 步骤 6 中的图像 3,3
    • Flip the motherboard to view the speaker cable connection on the underside.
    • Flip up the speaker cable ZIF locking flap.
    • Disconnect the touchpad ribbon cable.
  7. Dell Latitude 5480 Speakers Replacement: 步骤 7 中的图像 1,3 Dell Latitude 5480 Speakers Replacement: 步骤 7 中的图像 2,3 Dell Latitude 5480 Speakers Replacement: 步骤 7 中的图像 3,3
    • Disconnect the speaker cable by pulling it directly out of its motherboard port.
    • Do not pull on the wires.
  8. Dell Latitude 5480 Speakers Replacement: 步骤 8 中的图像 1,3 Dell Latitude 5480 Speakers Replacement: 步骤 8 中的图像 2,3 Dell Latitude 5480 Speakers Replacement: 步骤 8 中的图像 3,3
    • Carefully unseat the wire between the two speakers from the clips.
    • Lift the speakers up and out of the chassis.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 20
总计 210
