跳转到主内容
Dell Latitude 5480 Display Replacement
你所需要的
  1. Dell Latitude 5480 Display Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Use a Phillips screwdriver to remove the eight 5.6 mm screws that secure the lower case.
  2. Dell Latitude 5480 Display Replacement: 步骤 2 中的图像 1,3 Dell Latitude 5480 Display Replacement: 步骤 2 中的图像 2,3 Dell Latitude 5480 Display Replacement: 步骤 2 中的图像 3,3
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry up around the perimeter of the device until the lower case fully releases.
    • Lift off the lower case.
  3. Dell Latitude 5480 Display Replacement, Battery: 步骤 3 中的图像 1,2 Dell Latitude 5480 Display Replacement, Battery: 步骤 3 中的图像 2,2
    • Remove the four 5.6 mm Phillips screws that secure the battery.
  4. Dell Latitude 5480 Display Replacement: 步骤 4 中的图像 1,3 Dell Latitude 5480 Display Replacement: 步骤 4 中的图像 2,3 Dell Latitude 5480 Display Replacement: 步骤 4 中的图像 3,3
    • Lift the battery up and out of the chassis.
  5. Dell Latitude 5480 Display Replacement, Display: 步骤 5 中的图像 1,3 Dell Latitude 5480 Display Replacement, Display: 步骤 5 中的图像 2,3 Dell Latitude 5480 Display Replacement, Display: 步骤 5 中的图像 3,3
    • Insert a plastic card between the bezel and the display.
    • Slide the plastic card beneath the entire bezel to sever the adhesive that secures the bezel.
    • Lift the bezel off of the display.
  6. Dell Latitude 5480 Display Replacement: 步骤 6 中的图像 1,3 Dell Latitude 5480 Display Replacement: 步骤 6 中的图像 2,3 Dell Latitude 5480 Display Replacement: 步骤 6 中的图像 3,3
    • Remove the four 5.6 mm Phillips head screws, one at each corner, to release the display assembly.
    • Gently lift away the display panel and set it on top of the keyboard.
    • Take care not to strain the display assemble cable.
  7. Dell Latitude 5480 Display Replacement: 步骤 7 中的图像 1,3 Dell Latitude 5480 Display Replacement: 步骤 7 中的图像 2,3 Dell Latitude 5480 Display Replacement: 步骤 7 中的图像 3,3
    • On the bottom of the back of the display panel, remove the tape that secures the cable connecting the screen to the base of the computer.
    • Flip up the display cable locking bar.
    • Disconnect the display connector.
    • Remove the display.
结论
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 30
总计 269
