跳转到主内容
Dell Latitude 5310 Battery Replacement
你所需要的
  1. Dell Latitude 5310 Battery Replacement, open the back cover: 步骤 1 中的图像 1,3 Dell Latitude 5310 Battery Replacement, open the back cover: 步骤 1 中的图像 2,3 Dell Latitude 5310 Battery Replacement, open the back cover: 步骤 1 中的图像 3,3
    • place the laptop upside down on a soft, clean surface to avoid scratching
    • locate the screws (in this case 8)
    • use the screwdriver
    • 'Note: the screws are designe to stay attached in the back cover even after being unscrewed. This prevents loss.'
    • use the opening tool to open the back cover starting on the hinge areas. then move slowly around the edges
    • lift the open areas with your hand (lightly!) and slowly work using the tension along the edges.
  2. Dell Latitude 5310 Battery Replacement, remove the battery: 步骤 2 中的图像 1,2 Dell Latitude 5310 Battery Replacement, remove the battery: 步骤 2 中的图像 2,2
    • use the screwdriver to remove the screws which also stay attached
    • use your fingers to detach the battery connection cable from the motherboard
    • you can pick up the battery and take it out of the device
    • remove the connections cable from the "old" battery and insert to the new one
  3. Dell Latitude 5310 Battery Replacement, install new battery: 步骤 3 中的图像 1,2 Dell Latitude 5310 Battery Replacement, install new battery: 步骤 3 中的图像 2,2
    • insert the new battery and screw in
    • use the spudger to fix the connection cable then press with the flat of the spudger side to push it in
    • put the back cover on and use your palm to close softly
    • then screw the back cover back on
    • test if the device is working
    • Note: mostly the batterys are delivered empty so first you need to charge it maybe
    • its also possible to get the status of the battery: press F2 while starting to open bios settings then check battery status
结论
2等其他人完成本指南。
Oliver Sandmaier
于11/01/23注册
334 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 24
过去 30 天: 86
总计 446
