跳转到主内容
Dell Latitude 3520 System Fan Replacement
你所需要的
  1. Dell Latitude 3520 System Fan Replacement, Remove MicroSD-card: 步骤 1 中的图像 1,1
    • Push the microSD-card to eject it from the slot.
    • Remove the microSD-card from the computer.
  2. Dell Latitude 3520 System Fan Replacement, Bottom Case: 步骤 2 中的图像 1,3 Dell Latitude 3520 System Fan Replacement, Bottom Case: 步骤 2 中的图像 2,3 Dell Latitude 3520 System Fan Replacement, Bottom Case: 步骤 2 中的图像 3,3
    • Loosen the nine screws 2mm Phillips #0 that secure the base cover to the assembly.
    • Using a plastic scribe, pry open the base cover starting from the recesses located in the indents near the hinges at the top edge of the base cover.
    • Carefully lift and remove the base cover.
  3. Dell Latitude 3520 System Fan Replacement, Battery: 步骤 3 中的图像 1,1
    • Slide the metal above the connector on the battery to unlock.
  4. Dell Latitude 3520 System Fan Replacement: 步骤 4 中的图像 1,2 Dell Latitude 3520 System Fan Replacement: 步骤 4 中的图像 2,2
    • Peel the adhesive tapes and the battery cable.
  5. Dell Latitude 3520 System Fan Replacement: 步骤 5 中的图像 1,1
    • Disconnect the battery cable from the connector on the system board.
  6. Dell Latitude 3520 System Fan Replacement: 步骤 6 中的图像 1,2 Dell Latitude 3520 System Fan Replacement: 步骤 6 中的图像 2,2
    • Remove the three 2mm Phillip #0 screws that secure the battery in place.
  7. Dell Latitude 3520 System Fan Replacement: 步骤 7 中的图像 1,1
    • Lift and remove the battery.
  8. Dell Latitude 3520 System Fan Replacement, System Fan: 步骤 8 中的图像 1,1
    • Disconnect the system fan cable from the connector on the system board.
  9. Dell Latitude 3520 System Fan Replacement: 步骤 9 中的图像 1,1
    • Remove the two 2mm Phillips #0 screws that secure the system fan.
  10. Dell Latitude 3520 System Fan Replacement: 步骤 10 中的图像 1,1
    • Lift and remove the system fan.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 19
总计 133
