跳转到主内容
Dell Latitude 3520 RAMReplacement
你所需要的
  1. Dell Latitude 3520 RAMReplacement, Remove MicroSD-card: 步骤 1 中的图像 1,1
    • Push the microSD-card to eject it from the slot.
    • Remove the microSD-card from the computer.
  2. Dell Latitude 3520 RAMReplacement, Bottom Case: 步骤 2 中的图像 1,3 Dell Latitude 3520 RAMReplacement, Bottom Case: 步骤 2 中的图像 2,3 Dell Latitude 3520 RAMReplacement, Bottom Case: 步骤 2 中的图像 3,3
    • Loosen the nine screws 2mm Phillips #0 that secure the base cover to the assembly.
    • Using a plastic scribe, pry open the base cover starting from the recesses located in the indents near the hinges at the top edge of the base cover.
    • Carefully lift and remove the base cover.
  3. Dell Latitude 3520 RAMReplacement, RAM: 步骤 3 中的图像 1,2 Dell Latitude 3520 RAMReplacement, RAM: 步骤 3 中的图像 2,2
    • Lift the clips to find the memory module slot.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 13
总计 95
