跳转到主内容
Dell Latitude 3520 Bottom Case Replacement
你所需要的
  1. Dell Latitude 3520 Bottom Case Replacement, Bottom Case: 步骤 1 中的图像 1,3 Dell Latitude 3520 Bottom Case Replacement, Bottom Case: 步骤 1 中的图像 2,3 Dell Latitude 3520 Bottom Case Replacement, Bottom Case: 步骤 1 中的图像 3,3
    • Loosen the nine screws 2mm Phillips #0 that secure the base cover to the assembly.
    • Using a plastic scribe, pry open the base cover starting from the recesses located in the indents near the hinges at the top edge of the base cover.
    • Carefully lift and remove the base cover.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 86
