跳转到主内容
Dell Latitude 3500 VGA Board Replacement
你所需要的
  1. Dell Latitude 3500 VGA Board Replacement, Remove screws: 步骤 1 中的图像 1,1
    • 10 screws hold the bottom cover in place -- these stay in the bottom cover.
  2. Dell Latitude 3500 VGA Board Replacement, Separate bottom cover and palmrest: 步骤 2 中的图像 1,1
    • Using a spudger will make quick work of this step.
  3. Dell Latitude 3500 VGA Board Replacement, Disconnect and Remove Battery: 步骤 3 中的图像 1,1
    • Disconnect the battery cable from the motherboard.
    • Remove the 4 screws holding it in place
    • Battery can now be removed from device.
  4. Dell Latitude 3500 VGA Board Replacement, Disconnect Surrounding Connections from System Fan: 步骤 4 中的图像 1,1
    • Unplug the fan header
    • Unplug the VGA board cable
    • Unplug the LCD cable
  5. Dell Latitude 3500 VGA Board Replacement, Remove Fan Screws: 步骤 5 中的图像 1,1
    • Once these 2 screws are removed the fan will lift out as long as the cables are out of the way.
  6. Dell Latitude 3500 VGA Board Replacement, Disconnect VGA Board: 步骤 6 中的图像 1,1
    • Pull straight up from the motherboard
  7. Dell Latitude 3500 VGA Board Replacement, Remove Screws: 步骤 7 中的图像 1,1
    • 2 screws
    • Board can now be safely removed from device
结论
Jake
于03/08/23注册
1,327 声望
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 36
