跳转到主内容
Dell Latitude 3190 Power Switch Board Replacement
你所需要的
  1. Dell Latitude 3190 Power Switch Board Replacement, Base Cover: 步骤 1 中的图像 1,2 Dell Latitude 3190 Power Switch Board Replacement, Base Cover: 步骤 1 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the seven 7 mm screws securing the back case.
  2. Dell Latitude 3190 Power Switch Board Replacement: 步骤 2 中的图像 1,3 Dell Latitude 3190 Power Switch Board Replacement: 步骤 2 中的图像 2,3 Dell Latitude 3190 Power Switch Board Replacement: 步骤 2 中的图像 3,3
    • Using a plastic opening tool carefully separate the plastic base cover from the rest of the laptop.
    • Lift the bottom cover from the laptop.
  3. Dell Latitude 3190 Power Switch Board Replacement, Battery: 步骤 3 中的图像 1,1
    • Locate the battery.
  4. Dell Latitude 3190 Power Switch Board Replacement: 步骤 4 中的图像 1,3 Dell Latitude 3190 Power Switch Board Replacement: 步骤 4 中的图像 2,3 Dell Latitude 3190 Power Switch Board Replacement: 步骤 4 中的图像 3,3
    • Disconnect the battery cable located on the top of the battery.
    • Use the spudger and disconnect the battery cable.
    • Pull the cable out of the way.
  5. Dell Latitude 3190 Power Switch Board Replacement: 步骤 5 中的图像 1,3 Dell Latitude 3190 Power Switch Board Replacement: 步骤 5 中的图像 2,3 Dell Latitude 3190 Power Switch Board Replacement: 步骤 5 中的图像 3,3
    • Use a Phillips #0 screwdriver to remove the three 3 mm screws from the battery.
  6. Dell Latitude 3190 Power Switch Board Replacement: 步骤 6 中的图像 1,3 Dell Latitude 3190 Power Switch Board Replacement: 步骤 6 中的图像 2,3 Dell Latitude 3190 Power Switch Board Replacement: 步骤 6 中的图像 3,3
    • Pull the black battery tap upwards to remove the battery.
    • The battery adhesive is strong, do not be afraid to use force. You may need to use the spudger or opening tool as a wedge.
  7. Dell Latitude 3190 Power Switch Board Replacement, Power Switch Board: 步骤 7 中的图像 1,2 Dell Latitude 3190 Power Switch Board Replacement, Power Switch Board: 步骤 7 中的图像 2,2
    • Disconnect the power switch cable from the motherboard.
  8. Dell Latitude 3190 Power Switch Board Replacement: 步骤 8 中的图像 1,3 Dell Latitude 3190 Power Switch Board Replacement: 步骤 8 中的图像 2,3 Dell Latitude 3190 Power Switch Board Replacement: 步骤 8 中的图像 3,3
    • Remove the two 3 mm screws that secure the power switch board on the computer.
  9. Dell Latitude 3190 Power Switch Board Replacement: 步骤 9 中的图像 1,2 Dell Latitude 3190 Power Switch Board Replacement: 步骤 9 中的图像 2,2
    • Lift the power switchboard away from the computer.
结论
Haley Smith
于09/01/21注册
305 声望
创作了2篇指南
团队
Gateway, Team 1-5, Saknee Fall 2021 Gateway, Team 1-5, Saknee Fall 2021 的会员
GCC-SAKNEE-F21S1G5
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 10
总计 338
