跳转到主内容
Dell Latitude 3190 Motherboard Replacement
你所需要的
  1. Dell Latitude 3190 Motherboard Replacement, Base Cover: 步骤 1 中的图像 1,2 Dell Latitude 3190 Motherboard Replacement, Base Cover: 步骤 1 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the seven 7 mm screws securing the back case.
  2. Dell Latitude 3190 Motherboard Replacement: 步骤 2 中的图像 1,3 Dell Latitude 3190 Motherboard Replacement: 步骤 2 中的图像 2,3 Dell Latitude 3190 Motherboard Replacement: 步骤 2 中的图像 3,3
    • Using a plastic opening tool carefully separate the plastic base cover from the rest of the laptop.
    • Lift the bottom cover from the laptop.
  3. Dell Latitude 3190 Motherboard Replacement, Battery: 步骤 3 中的图像 1,1
    • Locate the battery.
  4. Dell Latitude 3190 Motherboard Replacement: 步骤 4 中的图像 1,3 Dell Latitude 3190 Motherboard Replacement: 步骤 4 中的图像 2,3 Dell Latitude 3190 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Disconnect the battery cable located on the top of the battery.
    • Use the spudger and disconnect the battery cable.
    • Pull the cable out of the way.
  5. Dell Latitude 3190 Motherboard Replacement: 步骤 5 中的图像 1,3 Dell Latitude 3190 Motherboard Replacement: 步骤 5 中的图像 2,3 Dell Latitude 3190 Motherboard Replacement: 步骤 5 中的图像 3,3
    • Use a Phillips #0 screwdriver to remove the three 3 mm screws from the battery.
  6. Dell Latitude 3190 Motherboard Replacement: 步骤 6 中的图像 1,3 Dell Latitude 3190 Motherboard Replacement: 步骤 6 中的图像 2,3 Dell Latitude 3190 Motherboard Replacement: 步骤 6 中的图像 3,3
    • Pull the black battery tap upwards to remove the battery.
    • The battery adhesive is strong, do not be afraid to use force. You may need to use the spudger or opening tool as a wedge.
  7. Dell Latitude 3190 Motherboard Replacement, M.2 SSD: 步骤 7 中的图像 1,3 Dell Latitude 3190 Motherboard Replacement, M.2 SSD: 步骤 7 中的图像 2,3 Dell Latitude 3190 Motherboard Replacement, M.2 SSD: 步骤 7 中的图像 3,3
    • Use a spudger to disconnect the battery cable from the motherboard located at the top of the battery.
  8. Dell Latitude 3190 Motherboard Replacement: 步骤 8 中的图像 1,3 Dell Latitude 3190 Motherboard Replacement: 步骤 8 中的图像 2,3 Dell Latitude 3190 Motherboard Replacement: 步骤 8 中的图像 3,3
    • Locate the M.2 SSD after the battery is removed
    • Use the Phillips #0 screwdriver to remove the 3 mm screw from the SSD.
    • Pull the M.2 SSD from the board.
  9. Dell Latitude 3190 Motherboard Replacement, Motherboard: 步骤 9 中的图像 1,3 Dell Latitude 3190 Motherboard Replacement, Motherboard: 步骤 9 中的图像 2,3 Dell Latitude 3190 Motherboard Replacement, Motherboard: 步骤 9 中的图像 3,3
    • Remove the motherboard cable by pulling up on the black bar and carefully removing the blue ribbon cable.
    • Disconnect the white speaker cable connector.
  10. Dell Latitude 3190 Motherboard Replacement: 步骤 10 中的图像 1,2 Dell Latitude 3190 Motherboard Replacement: 步骤 10 中的图像 2,2
    • Using a spudger, disconnect the black power board and audio cable.
    • Disconnect the white coin cell battery cable.
  11. Dell Latitude 3190 Motherboard Replacement: 步骤 11 中的图像 1,3 Dell Latitude 3190 Motherboard Replacement: 步骤 11 中的图像 2,3 Dell Latitude 3190 Motherboard Replacement: 步骤 11 中的图像 3,3
    • Use the Phillips #0 screwdriver to remove the 3 mm screw and lift the metal bracket that secures the WLAN card on the system board.
    • Disconnect the black and white WLAN cables.
  12. Dell Latitude 3190 Motherboard Replacement: 步骤 12 中的图像 1,2 Dell Latitude 3190 Motherboard Replacement: 步骤 12 中的图像 2,2
    • Remove the screw that secures the camera cable to the system board.
    • Disconnect camera cable.
    • Disconnect the black sensor cable.
  13. Dell Latitude 3190 Motherboard Replacement: 步骤 13 中的图像 1,3 Dell Latitude 3190 Motherboard Replacement: 步骤 13 中的图像 2,3 Dell Latitude 3190 Motherboard Replacement: 步骤 13 中的图像 3,3
    • Use the Phillips #0 screwdriver to remove the two 3 mm screws from the metal bracket on the display cable.
    • Lift the metal bracket that secures the display cable on the computer.
    • Disconnect the black display cable using a spudger or pull it out by hand.
  14. Dell Latitude 3190 Motherboard Replacement: 步骤 14 中的图像 1,3 Dell Latitude 3190 Motherboard Replacement: 步骤 14 中的图像 2,3 Dell Latitude 3190 Motherboard Replacement: 步骤 14 中的图像 3,3
    • Disconnect the white power connector.
    • Use the spudger to lift up on black bar to release the trackpad ribbon cable.
    • Pull the blue tab release to the cable from the connector.
  15. Dell Latitude 3190 Motherboard Replacement: 步骤 15 中的图像 1,3 Dell Latitude 3190 Motherboard Replacement: 步骤 15 中的图像 2,3 Dell Latitude 3190 Motherboard Replacement: 步骤 15 中的图像 3,3
    • Use a Phillips #0 tp remove the two 3 mm screws on the metal bracket that secures the board.
    • Remove the metal bracket.
  16. Dell Latitude 3190 Motherboard Replacement: 步骤 16 中的图像 1,3 Dell Latitude 3190 Motherboard Replacement: 步骤 16 中的图像 2,3 Dell Latitude 3190 Motherboard Replacement: 步骤 16 中的图像 3,3
    • Use the Phillips #0 screwdriver to remove the five 3 mm screws that secure the motherboard.
  17. Dell Latitude 3190 Motherboard Replacement: 步骤 17 中的图像 1,3 Dell Latitude 3190 Motherboard Replacement: 步骤 17 中的图像 2,3 Dell Latitude 3190 Motherboard Replacement: 步骤 17 中的图像 3,3
    • Carefully lift the motherboard up to remove it from the computer.
    • Make sure not to snag any of the other cables.
结论
另外一个人完成了本指南。
Sean Gherkins
于12/26/17注册
292 声望
创作了2篇指南
团队
Gateway, Team 1-5, Saknee Fall 2021 Gateway, Team 1-5, Saknee Fall 2021 的会员
GCC-SAKNEE-F21S1G5
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 48
总计 1,114
