跳转到主内容
Dell Latitude 3189 SSD Replacement
你所需要的
  1. Dell Latitude 3189 SSD Replacement, Lower Case: 步骤 1 中的图像 1,2 Dell Latitude 3189 SSD Replacement, Lower Case: 步骤 1 中的图像 2,2
    • Before beginning, power off and unplug the device.
    • Use a Phillips screwdriver to loosen the seven captive screws that secure the lower case.
  2. Dell Latitude 3189 SSD Replacement: 步骤 2 中的图像 1,3 Dell Latitude 3189 SSD Replacement: 步骤 2 中的图像 2,3 Dell Latitude 3189 SSD Replacement: 步骤 2 中的图像 3,3
    • Insert a nylon spudger between the lower case and chassis at the two hinge spaces on the back side of the laptop and pry up the lower case.
    • Do not use metal items to pry the base cover off, like a screwdriver, as it could slip and damage internal components.
    • Avoid prying at the ports.
  3. Dell Latitude 3189 SSD Replacement: 步骤 3 中的图像 1,2 Dell Latitude 3189 SSD Replacement: 步骤 3 中的图像 2,2
    • Grip and lift the lower case up and away.
    • If you feel any significant resistance, double check that all of the screws are loosened.
  4. Dell Latitude 3189 SSD Replacement: 步骤 4 中的图像 1,3 Dell Latitude 3189 SSD Replacement: 步骤 4 中的图像 2,3 Dell Latitude 3189 SSD Replacement: 步骤 4 中的图像 3,3
    • Before performing any operations within the laptop, unplug the battery.
    • Pull the white battery connector directly out of its motherboard port.
    • Do not pull on the wires.
  5. Dell Latitude 3189 SSD Replacement, SSD: 步骤 5 中的图像 1,2 Dell Latitude 3189 SSD Replacement, SSD: 步骤 5 中的图像 2,2
    • Use a Phillips screwdriver to remove the single 3.2 mm screw that secures the SSD.
    • The SSD will pop up a few millimeters; this is normal.
  6. Dell Latitude 3189 SSD Replacement: 步骤 6 中的图像 1,1
    • Gently pull the SSD out of its socket, maintaining the same angle that it flipped up to.
    • Do not pull directly up on the SSD after the screw is removed as you could damage the SSD and/or the connector.
结论
3等其他人完成本指南。
Maximus
于02/14/24注册
198 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 33
总计 436
