跳转到主内容
Dell Latitude 10-ST2e Battery Replacement
你所需要的
  1. Dell Latitude 10-ST2e Battery Replacement, Battery: 步骤 1 中的图像 1,3 Dell Latitude 10-ST2e Battery Replacement, Battery: 步骤 1 中的图像 2,3 Dell Latitude 10-ST2e Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Place tablet face-down on flat surface.
    • Using the blue opening tool, separate the back plastic cover from the device. Start in a corner, and work your way around the tablet.
  2. Dell Latitude 10-ST2e Battery Replacement: 步骤 2 中的图像 1,2 Dell Latitude 10-ST2e Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the four 7.0mm screws securing the battery with a JIS #00 screwdriver.
  3. Dell Latitude 10-ST2e Battery Replacement: 步骤 3 中的图像 1,2 Dell Latitude 10-ST2e Battery Replacement: 步骤 3 中的图像 2,2
    • With the blue opening tool, gently lift up and remove the battery from the tablet.
    • Do not damage, puncture, cut, or bend the battery, as this may cause bodily harm.
结论
4等其他人完成本指南。
Vincent Hoffman
于09/25/17注册
261 声望
创作了2篇指南
团队
USF Tampa, Team S16-G4, Eyestone Fall 2017 USF Tampa, Team S16-G4, Eyestone Fall 2017 的会员
USFT-EYESTONE-F17S16G4
4 名成员
创作了13篇指南
一条评论
I found that the down volume control was jammed by the case. So be careful with the reassembly around the volume control.
James Smith - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 16
总计 2,446
