跳转到主内容
Dell Inspiron n5110 Hard Drive Replacement
你所需要的
  1. Dell Inspiron n5110 Hard Drive Replacement, Remove the Screws: 步骤 1 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the hard-drive assembly to the system board.
  2. Dell Inspiron n5110 Hard Drive Replacement, Sliding the Hard Drive Assembly: 步骤 2 中的图像 1,1
    • Slide the hard-drive assembly to disconnect it from the system-board connector.
  3. Dell Inspiron n5110 Hard Drive Replacement, Lifting the Hard-Drive Assembly: 步骤 3 中的图像 1,1
    • Lift the hard-drive assembly off the system board.
  4. Dell Inspiron n5110 Hard Drive Replacement, Remove the Screws: 步骤 4 中的图像 1,1
    • Remove the four screws that secure the hard drive to the hard-drive bracket.
  5. Dell Inspiron n5110 Hard Drive Replacement, Lifting the Hard Drive: 步骤 5 中的图像 1,1
    • Lift the hard drive away from the hard-drive bracket.
  6. Dell Inspiron n5110 Hard Drive Replacement, Placing the Hard Drive: 步骤 6 中的图像 1,1
    • Place the NEW hard drive in the hard-drive bracket.
  7. Dell Inspiron n5110 Hard Drive Replacement, Replace the Screws: 步骤 7 中的图像 1,1
    • Replace the four screws that secure the hard drive to the hard-drive bracket.
  8. Dell Inspiron n5110 Hard Drive Replacement, Placing the Hard-Drive Assembly: 步骤 8 中的图像 1,1
    • Place the hard-drive assembly on the system board.
  9. Dell Inspiron n5110 Hard Drive Replacement, Sliding the Hard-Drive Assembly: 步骤 9 中的图像 1,1
    • Slide the hard-drive assembly to connect it to the system-board connector.
  10. Dell Inspiron n5110 Hard Drive Replacement, Replace the Screws: 步骤 10 中的图像 1,1
    • Replace the two screws that secure the hard-drive assembly to the system-board.
终点
3等其他人完成本指南。
Terrence15
于12/18/17注册
79,121 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 48
总计 2,935
