跳转到主内容
Dell Inspiron n5050 RAM Replacement
你所需要的
  1. 注意:步骤 1-3 源自标记为进行中的 指南
    Dell Inspiron n5050 RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip your laptop over to view the bottom and locate the two locks.
  2. Dell Inspiron n5050 RAM Replacement: 步骤 2 中的图像 1,1
    • Slide the two locks away from each other.
    • Sliding these locks will loosen the battery to allow removal.
  3. Dell Inspiron n5050 RAM Replacement: 步骤 3 中的图像 1,2 Dell Inspiron n5050 RAM Replacement: 步骤 3 中的图像 2,2
    • Pull battery out of the laptop.
    • Your laptop's battery should be completely removed.
  4. Dell Inspiron n5050 RAM Replacement, Keyboard: 步骤 4 中的图像 1,2 Dell Inspiron n5050 RAM Replacement, Keyboard: 步骤 4 中的图像 2,2
    • Flip the laptop right side up. Open the laptop.
    • Gently press in the four retaining tabs along the top of the keyboard with a spudger, one at a time.
    • After the first tab is released, gently lift up on the keyboard so it doesn't lock again. Finish the other three tabs while gently lifting up on the keyboard. The keyboard will hinge up along the bottom.
  5. Dell Inspiron n5050 RAM Replacement: 步骤 5 中的图像 1,3 Dell Inspiron n5050 RAM Replacement: 步骤 5 中的图像 2,3 Dell Inspiron n5050 RAM Replacement: 步骤 5 中的图像 3,3
    • Gently flip the data cable latch away from the data cable with flat side of spudger.
    • Lift the cable up and out.
    • When reinstalling cable, there are two retainer wings on the sides of the cable that the cable that lock onto the bottom of the cable latch area. When these are in place the cable is properly inserted.
    • For removing the optical drive you don't need to disconnect the keyboard ribbon cable.
    What do I do is i broke the cable retainer wings and the black thing?
    Wezley Joao Ferreira - 回复
    If the connector on the motherboard is still attached and only the clip is broken you can try and find a new clip, or perhaps tape the keyboard in place with electrical tape.
    Tyler - 回复
    I didn’t need to disconnect and remove the cable. I simply set the keyboard gently to the side. This gave me full access to the two RAM module slots for replacement. Hopefully this will make the procedure easier.
    Clemmitt Sigler - 回复
  6. Dell Inspiron n5050 RAM Replacement, RAM: 步骤 6 中的图像 1,3 Dell Inspiron n5050 RAM Replacement, RAM: 步骤 6 中的图像 2,3 Dell Inspiron n5050 RAM Replacement, RAM: 步骤 6 中的图像 3,3
    • Locate RAM
    • Push outwards on both retaining clips, the RAM will pop up slightly when it is free from the clips.
  7. Dell Inspiron n5050 RAM Replacement: 步骤 7 中的图像 1,1
    • The RAM will pop up, and then you can slide it out at the same angle it is at.
结论
8等其他人完成本指南。
Tyler
于06/19/12注册
4,920 声望
创作了16篇指南
团队
TechForce TechForce 的会员
Business
2 名成员
创作了25篇指南
一条评论
Dell Inspiron 15 - M5040 N5040 N5050 disassembly
https://youtu.be/3c5P0pJgckg
mohamed - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 10,311
