跳转到主内容
Dell Inspiron n5050 Display Replacement
你所需要的
  1. 注意:步骤 1-3 源自标记为进行中的 指南
    Dell Inspiron n5050 Display Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip your laptop over to view the bottom and locate the two locks.
  2. Dell Inspiron n5050 Display Replacement: 步骤 2 中的图像 1,1
    • Slide the two locks away from each other.
    • Sliding these locks will loosen the battery to allow removal.
  3. Dell Inspiron n5050 Display Replacement: 步骤 3 中的图像 1,2 Dell Inspiron n5050 Display Replacement: 步骤 3 中的图像 2,2
    • Pull battery out of the laptop.
    • Your laptop's battery should be completely removed.
  4. Dell Inspiron n5050 Display Replacement, Display: 步骤 4 中的图像 1,1
    • Flip laptop right side up and open
    • Insert flat side of spudger gently along inside of screen and screen surround.
    • Work your way around the screen carefully releasing the screen surround from the lid.
    • The screen surround is held in place by delicate plastic clips, so don't use too much force.
  5. Dell Inspiron n5050 Display Replacement: 步骤 5 中的图像 1,1
    • Unplug the cable from the camera.
    • Unscrew the six screws attaching the display support frame to the laptop lid. Lower lid to desk.
    • The lid still has the WIFI antenna connected to it.
    • When reassembling, plug the cable to the camera first, then screw in the lid.
  6. Dell Inspiron n5050 Display Replacement: 步骤 6 中的图像 1,3 Dell Inspiron n5050 Display Replacement: 步骤 6 中的图像 2,3 Dell Inspiron n5050 Display Replacement: 步骤 6 中的图像 3,3
    • Unplug the cable from the display.
    • This cable has delicate wires that can easily break. It is glued to the back of the display, but can be carefully peeled away.
    • The plug is held in on the sides with two clips. Gently pull on the each side of the cable to remove it from its connector.
  7. Dell Inspiron n5050 Display Replacement: 步骤 7 中的图像 1,2 Dell Inspiron n5050 Display Replacement: 步骤 7 中的图像 2,2
    • For this part, it is easiest to use a magnetized screw driver.
    • Unscrew display from display hinge/support bracket. There are two screws on each side.
    • Unscrew the bottom screws first.
    • Unscrew the top screws while holding onto the screen with your other hand so it doesn't fall.
结论
6等其他人完成本指南。
Tyler
于06/19/12注册
4,920 声望
创作了16篇指南
团队
TechForce TechForce 的会员
Business
2 名成员
创作了25篇指南
4条评论
i cant figure out how to take off the cable to the display help
timothyamorrison - 回复
This should be listed as "easy", and time taken around 10-15 minutes.
Paul Freeman-Powell - 回复
Agreed should be labeled easier. 10-15 minutes
Jake Fisher - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 28
总计 10,507
