跳转到主内容
Dell Inspiron i3558-5500BLK Internal Fan Replacement
你所需要的
  1. Dell Inspiron i3558-5500BLK Internal Fan Replacement, Keyboard: 步骤 1 中的图像 1,2 Dell Inspiron i3558-5500BLK Internal Fan Replacement, Keyboard: 步骤 1 中的图像 2,2
    • With the laptop open and facing upright, use the Spudger to pull at the notches shown in the image.
  2. Dell Inspiron i3558-5500BLK Internal Fan Replacement: 步骤 2 中的图像 1,3 Dell Inspiron i3558-5500BLK Internal Fan Replacement: 步骤 2 中的图像 2,3 Dell Inspiron i3558-5500BLK Internal Fan Replacement: 步骤 2 中的图像 3,3
    • Gently turn the keyboard over to reveal the ribbon cable underneath. Remove the cable from the motherboard by lifting the white release tab and gently pulling the cable away from the socket.
    • Lift the keyboard away from the baseboard to remove.
  3. Dell Inspiron i3558-5500BLK Internal Fan Replacement, Battery: 步骤 3 中的图像 1,3 Dell Inspiron i3558-5500BLK Internal Fan Replacement, Battery: 步骤 3 中的图像 2,3 Dell Inspiron i3558-5500BLK Internal Fan Replacement, Battery: 步骤 3 中的图像 3,3
    • With the back of the laptop facing upright, press the switch shown to loosen the battery and remove it.
  4. Dell Inspiron i3558-5500BLK Internal Fan Replacement, Back Cover: 步骤 4 中的图像 1,2 Dell Inspiron i3558-5500BLK Internal Fan Replacement, Back Cover: 步骤 4 中的图像 2,2
    • With the laptop facing upright - remove the ribbon cable from the optical drive by lifting the white release tab and gently pulling the cable away from the socket.
  5. Dell Inspiron i3558-5500BLK Internal Fan Replacement: 步骤 5 中的图像 1,2 Dell Inspiron i3558-5500BLK Internal Fan Replacement: 步骤 5 中的图像 2,2
    • Slide the optical drive out of the port on the right-side of the laptop.
  6. Dell Inspiron i3558-5500BLK Internal Fan Replacement: 步骤 6 中的图像 1,3 Dell Inspiron i3558-5500BLK Internal Fan Replacement: 步骤 6 中的图像 2,3 Dell Inspiron i3558-5500BLK Internal Fan Replacement: 步骤 6 中的图像 3,3
    • With the back of the laptop facing upright, remove the following screws:
    • Ten 0.5 mm Phillips screws from the backboard
    • One 0.2 mm Phillips screw from the battery port
    • Three 0.1 mm Phillips screws from the optical drive slot.
  7. Dell Inspiron i3558-5500BLK Internal Fan Replacement: 步骤 7 中的图像 1,2 Dell Inspiron i3558-5500BLK Internal Fan Replacement: 步骤 7 中的图像 2,2
    • Gently pry the back cover from the opposite side of the battery to reveal the internal components.
  8. Dell Inspiron i3558-5500BLK Internal Fan Replacement, Internal Fan: 步骤 8 中的图像 1,3 Dell Inspiron i3558-5500BLK Internal Fan Replacement, Internal Fan: 步骤 8 中的图像 2,3 Dell Inspiron i3558-5500BLK Internal Fan Replacement, Internal Fan: 步骤 8 中的图像 3,3
    • Identify the fan assembly as shown in the image.
    • Remove the power cable by gently pulling it away from the fixture.
  9. Dell Inspiron i3558-5500BLK Internal Fan Replacement: 步骤 9 中的图像 1,2 Dell Inspiron i3558-5500BLK Internal Fan Replacement: 步骤 9 中的图像 2,2
    • Loosen the three 2 mm Phillips heatsink screws.
    • Remove the 0.5 mm Phillips fastener screw, identified by the red circle.
    • Remove the fan from the motherboard.
  10. Dell Inspiron i3558-5500BLK Internal Fan Replacement: 步骤 10 中的图像 1,3 Dell Inspiron i3558-5500BLK Internal Fan Replacement: 步骤 10 中的图像 2,3 Dell Inspiron i3558-5500BLK Internal Fan Replacement: 步骤 10 中的图像 3,3
    • Unfasten the screws shown in the image to remove the cover and heatsink from the fan unit.
结论
Nathan Ybanez
于09/27/17注册
622 声望
创作了6篇指南
团队
Cal Poly, Team S9-G5, Banghart Fall 2017 Cal Poly, Team S9-G5, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S9G5
4 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 309
