跳转到主内容
Dell Inspiron i3558-5500BLK Back Cover Replacement
你所需要的
  1. Dell Inspiron i3558-5500BLK Back Cover Replacement, Keyboard: 步骤 1 中的图像 1,2 Dell Inspiron i3558-5500BLK Back Cover Replacement, Keyboard: 步骤 1 中的图像 2,2
    • With the laptop open and facing upright, use the Spudger to pull at the notches shown in the image.
  2. Dell Inspiron i3558-5500BLK Back Cover Replacement: 步骤 2 中的图像 1,3 Dell Inspiron i3558-5500BLK Back Cover Replacement: 步骤 2 中的图像 2,3 Dell Inspiron i3558-5500BLK Back Cover Replacement: 步骤 2 中的图像 3,3
    • Gently turn the keyboard over to reveal the ribbon cable underneath. Remove the cable from the motherboard by lifting the white release tab and gently pulling the cable away from the socket.
    • Lift the keyboard away from the baseboard to remove.
  3. Dell Inspiron i3558-5500BLK Back Cover Replacement, Battery: 步骤 3 中的图像 1,3 Dell Inspiron i3558-5500BLK Back Cover Replacement, Battery: 步骤 3 中的图像 2,3 Dell Inspiron i3558-5500BLK Back Cover Replacement, Battery: 步骤 3 中的图像 3,3
    • With the back of the laptop facing upright, press the switch shown to loosen the battery and remove it.
  4. Dell Inspiron i3558-5500BLK Back Cover Replacement, Back Cover: 步骤 4 中的图像 1,2 Dell Inspiron i3558-5500BLK Back Cover Replacement, Back Cover: 步骤 4 中的图像 2,2
    • With the laptop facing upright - remove the ribbon cable from the optical drive by lifting the white release tab and gently pulling the cable away from the socket.
  5. Dell Inspiron i3558-5500BLK Back Cover Replacement: 步骤 5 中的图像 1,2 Dell Inspiron i3558-5500BLK Back Cover Replacement: 步骤 5 中的图像 2,2
    • Slide the optical drive out of the port on the right-side of the laptop.
  6. Dell Inspiron i3558-5500BLK Back Cover Replacement: 步骤 6 中的图像 1,3 Dell Inspiron i3558-5500BLK Back Cover Replacement: 步骤 6 中的图像 2,3 Dell Inspiron i3558-5500BLK Back Cover Replacement: 步骤 6 中的图像 3,3
    • With the back of the laptop facing upright, remove the following screws:
    • Ten 0.5 mm Phillips screws from the backboard
    • One 0.2 mm Phillips screw from the battery port
    • Three 0.1 mm Phillips screws from the optical drive slot.
  7. Dell Inspiron i3558-5500BLK Back Cover Replacement: 步骤 7 中的图像 1,2 Dell Inspiron i3558-5500BLK Back Cover Replacement: 步骤 7 中的图像 2,2
    • Gently pry the back cover from the opposite side of the battery to reveal the internal components.
结论
另外一个人完成了本指南。
Nathan Ybanez
于09/27/17注册
622 声望
创作了6篇指南
团队
Cal Poly, Team S9-G5, Banghart Fall 2017 Cal Poly, Team S9-G5, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S9G5
4 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,084
