跳转到主内容
Dell Inspiron One 2020 Hard Drive Replacement
你所需要的
  1. Dell Inspiron One 2020 Hard Drive Replacement, Back Cover: 步骤 1 中的图像 1,3 Dell Inspiron One 2020 Hard Drive Replacement, Back Cover: 步骤 1 中的图像 2,3 Dell Inspiron One 2020 Hard Drive Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Place the all in one computer face down on a soft, clean surface to avoid scratching the front.
    • Press the tab on the stand cover and lift up.
  2. Dell Inspiron One 2020 Hard Drive Replacement: 步骤 2 中的图像 1,3 Dell Inspiron One 2020 Hard Drive Replacement: 步骤 2 中的图像 2,3 Dell Inspiron One 2020 Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Remove the four phillips screws that attach the stand to the computer.
    • Tilt the stand up and out.
  3. Dell Inspiron One 2020 Hard Drive Replacement: 步骤 3 中的图像 1,3 Dell Inspiron One 2020 Hard Drive Replacement: 步骤 3 中的图像 2,3 Dell Inspiron One 2020 Hard Drive Replacement: 步骤 3 中的图像 3,3
    • Starting from the optical drive, pry the back cover up with a plastic spudger.
    • The cover is held in place by fragile plastic clips. Careful to not break them.
  4. Dell Inspiron One 2020 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,2 Dell Inspiron One 2020 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 2,2
    • Remove the three screws that hold the hard drive cage to the chassis.
  5. Dell Inspiron One 2020 Hard Drive Replacement: 步骤 5 中的图像 1,2 Dell Inspiron One 2020 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Slide the hard drive cage out slightly to access and remove the power and SATA cable.
    • There isn't much slack in these cables, so don't slide the hard drive cage to far.
    • The power and SATA cables are connected together. On most other computers, these connectors are separate.
    • Lift the hard drive cage out.
  6. Dell Inspiron One 2020 Hard Drive Replacement: 步骤 6 中的图像 1,3 Dell Inspiron One 2020 Hard Drive Replacement: 步骤 6 中的图像 2,3 Dell Inspiron One 2020 Hard Drive Replacement: 步骤 6 中的图像 3,3
    • Remove the four screws (two on each side) that attach the hard drive cage to the hard drive.
    • Lift the hard drive cage off the hard drive.
结论
35等其他人完成本指南。
Tyler
于06/19/12注册
4,920 声望
创作了16篇指南
团队
TechForce TechForce 的会员
Business
2 名成员
创作了25篇指南
3条评论
Thanks for this info this is very useful
Thank you once again
Ketan Valsangkar - 回复
Good Job, short and sweet and easy to follow
schmidtrg - 回复
Really useful information thank you.
Jessie Colon - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 21
过去 30 天: 80
总计 35,746
