简介
Before disassembling this device further, have a screwdriver and a plastic opening tool nearby. This section of the guide involves removing the keyboard, so make sure you carefully pull the keyboard cable to prevent damaging it.
你所需要的
Remove the eleven 5mm palmrest screws from the bottom of the laptop with a Phillips #PH00 screw.
Remove the two 3mm hard drive screws from the bottom of the laptop with a Phillips #PH00 screw.
11等其他人完成本指南。
