跳转到主内容
Dell Inspiron N5030 RAM Replacement
你所需要的
  1. Dell Inspiron N5030 RAM Replacement, Battery: 步骤 1 中的图像 1,2 Dell Inspiron N5030 RAM Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the computer over on its back so the battery compartment faces towards you.
    • Place your fingers on the small buttons with arrows pointing outwards.
    • Push and slide the buttons outward to unlock the battery compartment.
  2. Dell Inspiron N5030 RAM Replacement: 步骤 2 中的图像 1,2 Dell Inspiron N5030 RAM Replacement: 步骤 2 中的图像 2,2
    • Grab the battery and pull it towards yourself.
    • Remove the battery.
  3. Dell Inspiron N5030 RAM Replacement, Keyboard: 步骤 3 中的图像 1,1
    • Use a Phillips #0 screwdriver to unscrew the sixteen 0.6 mm screws on the back panel.
  4. Dell Inspiron N5030 RAM Replacement: 步骤 4 中的图像 1,1
    • Flip over the laptop and open it so that the screen faces you.
  5. Dell Inspiron N5030 RAM Replacement: 步骤 5 中的图像 1,1
    • Use the plastic opening tool and your fingers to pry off the top panel.
    • Pry the panel off starting at any one of the corners and then continue around the edges of the computer.
  6. Dell Inspiron N5030 RAM Replacement: 步骤 6 中的图像 1,1
    • Be careful when lifting off the keyboard panel. There are multiple delicate cables connecting the panel to the motherboard.
    • Pull up on the blue plastic tab connected by the white strip to unhook the keyboard panel from the motherboard.
  7. Dell Inspiron N5030 RAM Replacement: 步骤 7 中的图像 1,1
    • Flip up the small locking flap on the keyboard cable ZIF socket and disconnect the keyboard ribbon cable.
  8. Dell Inspiron N5030 RAM Replacement: 步骤 8 中的图像 1,1
    • Pull up on the wire tab with the blue, white, black, and red wires to detach the speakers from the motherboard.
  9. Dell Inspiron N5030 RAM Replacement: 步骤 9 中的图像 1,1
    • Remove the top keyboard panel.
  10. Dell Inspiron N5030 RAM Replacement, RAM: 步骤 10 中的图像 1,1
    • Place your fingers on the two metal tabs on the edges of the RAM.
    • Push on the tabs in the opposite direction.
    • The top RAM board will pop up after you push on the metal tabs.
  11. Dell Inspiron N5030 RAM Replacement: 步骤 11 中的图像 1,1
    • Pull the top RAM board out with your fingers.
  12. Dell Inspiron N5030 RAM Replacement: 步骤 12 中的图像 1,3 Dell Inspiron N5030 RAM Replacement: 步骤 12 中的图像 2,3 Dell Inspiron N5030 RAM Replacement: 步骤 12 中的图像 3,3
    • Repeat the above RAM board steps for the second RAM board.
结论
5等其他人完成本指南。
Rodrigo Perez
于04/23/14注册
230 声望
撰写一个指南
团队
Cal Poly, Team 10-59, Amido Spring 2014 Cal Poly, Team 10-59, Amido Spring 2014 的会员
CPSU-AMIDO-S14S10G59
4 名成员
创作了5篇指南
2条评论
Looking at the Dell service manual. You dont need to remove any screws, but only the keyboard, and if your careful you dont need to remove the ribbon cable. Its all in the service manual you can download free from Dell.
swestonj - 回复
swestonj is incorrect. The manual clearly states that you must remove the screws:
Service Manual
Removing the Keyboard
1. Follow the instructions in Before You Begin.
2. Remove the battery (see Removing the Battery).
3. Remove the two screws that secure the keyboard to the computer base.
etc.
mike -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 13
总计 5,440
