跳转到主内容
Dell Inspiron N5030 Keyboard Replacement
你所需要的
  1. Dell Inspiron N5030 Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 Dell Inspiron N5030 Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the computer over on its back so the battery compartment faces towards you.
    • Place your fingers on the small buttons with arrows pointing outwards.
    • Push and slide the buttons outward to unlock the battery compartment.
  2. Dell Inspiron N5030 Keyboard Replacement: 步骤 2 中的图像 1,2 Dell Inspiron N5030 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Grab the battery and pull it towards yourself.
    • Remove the battery.
  3. Dell Inspiron N5030 Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,1
    • Use a Phillips #0 screwdriver to unscrew the sixteen 0.6 mm screws on the back panel.
  4. Dell Inspiron N5030 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Flip over the laptop and open it so that the screen faces you.
  5. Dell Inspiron N5030 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Use the plastic opening tool and your fingers to pry off the top panel.
    • Pry the panel off starting at any one of the corners and then continue around the edges of the computer.
  6. Dell Inspiron N5030 Keyboard Replacement: 步骤 6 中的图像 1,1
    • Be careful when lifting off the keyboard panel. There are multiple delicate cables connecting the panel to the motherboard.
    • Pull up on the blue plastic tab connected by the white strip to unhook the keyboard panel from the motherboard.
  7. Dell Inspiron N5030 Keyboard Replacement: 步骤 7 中的图像 1,1
    • Flip up the small locking flap on the keyboard cable ZIF socket and disconnect the keyboard ribbon cable.
  8. Dell Inspiron N5030 Keyboard Replacement: 步骤 8 中的图像 1,1
    • Pull up on the wire tab with the blue, white, black, and red wires to detach the speakers from the motherboard.
  9. Dell Inspiron N5030 Keyboard Replacement: 步骤 9 中的图像 1,1
    • Remove the top keyboard panel.
结论
5等其他人完成本指南。
团队
Cal Poly, Team 10-59, Amido Spring 2014 Cal Poly, Team 10-59, Amido Spring 2014 的会员
CPSU-AMIDO-S14S10G59
4 名成员
创作了5篇指南
2指南评论
What if i broke the blue ribbons connection to the keyboard
oibrahimopeyemi - 回复
This solution is quite troublesome and does not explain how to disconnect / re-connect the wide flat keyboard cable. For a simpler solution see :
https://www.youtube.com/watch?v=jWuGb9AA...
Agropecuaria El Sinu - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 61
总计 3,058
