跳转到主内容
Dell Inspiron N5030 Disc Drive Replacement
你所需要的
  1. Dell Inspiron N5030 Disc Drive Replacement, Battery: 步骤 1 中的图像 1,2 Dell Inspiron N5030 Disc Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the computer over on its back so the battery compartment faces towards you.
    • Place your fingers on the small buttons with arrows pointing outwards.
    • Push and slide the buttons outward to unlock the battery compartment.
  2. Dell Inspiron N5030 Disc Drive Replacement: 步骤 2 中的图像 1,2 Dell Inspiron N5030 Disc Drive Replacement: 步骤 2 中的图像 2,2
    • Grab the battery and pull it towards yourself.
    • Remove the battery.
  3. Dell Inspiron N5030 Disc Drive Replacement, Keyboard: 步骤 3 中的图像 1,1
    • Use a Phillips #0 screwdriver to unscrew the sixteen 0.6 mm screws on the back panel.
  4. Dell Inspiron N5030 Disc Drive Replacement: 步骤 4 中的图像 1,1
    • Flip over the laptop and open it so that the screen faces you.
  5. Dell Inspiron N5030 Disc Drive Replacement: 步骤 5 中的图像 1,1
    • Use the plastic opening tool and your fingers to pry off the top panel.
    • Pry the panel off starting at any one of the corners and then continue around the edges of the computer.
  6. Dell Inspiron N5030 Disc Drive Replacement: 步骤 6 中的图像 1,1
    • Be careful when lifting off the keyboard panel. There are multiple delicate cables connecting the panel to the motherboard.
    • Pull up on the blue plastic tab connected by the white strip to unhook the keyboard panel from the motherboard.
  7. Dell Inspiron N5030 Disc Drive Replacement: 步骤 7 中的图像 1,1
    • Flip up the small locking flap on the keyboard cable ZIF socket and disconnect the keyboard ribbon cable.
  8. Dell Inspiron N5030 Disc Drive Replacement: 步骤 8 中的图像 1,1
    • Pull up on the wire tab with the blue, white, black, and red wires to detach the speakers from the motherboard.
  9. Dell Inspiron N5030 Disc Drive Replacement: 步骤 9 中的图像 1,1
    • Remove the top keyboard panel.
  10. Dell Inspiron N5030 Disc Drive Replacement, Disc Drive: 步骤 10 中的图像 1,1
    • Use a Phillips #0 screwdriver to unscrew one 0.6 mm screw located just to the left of the disc drive.
  11. Dell Inspiron N5030 Disc Drive Replacement: 步骤 11 中的图像 1,1
    • Position your thumbs to push firmly and slide the disc drive to the right through the rectangular hole in the side of the laptop and out.
结论
3等其他人完成本指南。
Charles
于04/22/14注册
579 声望
创作了2篇指南
团队
Cal Poly, Team 10-59, Amido Spring 2014 Cal Poly, Team 10-59, Amido Spring 2014 的会员
CPSU-AMIDO-S14S10G59
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 13
总计 2,029
