跳转到主内容
Dell Inspiron N5010 Memory Modules Replacement
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer)
    • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory module securing clips.
  1. Dell Inspiron N5010 Memory Modules Replacement, Popping up the Memory Module: 步骤 2 中的图像 1,2 Dell Inspiron N5010 Memory Modules Replacement, Popping up the Memory Module: 步骤 2 中的图像 2,2
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the module pops up.
  2. Dell Inspiron N5010 Memory Modules Replacement, Remove the Memory Module: 步骤 3 中的图像 1,1
    • Remove the memory module from the memory-module connector.
  3. Dell Inspiron N5010 Memory Modules Replacement, Align the Notch: 步骤 4 中的图像 1,2 Dell Inspiron N5010 Memory Modules Replacement, Align the Notch: 步骤 4 中的图像 2,2
    • Align the notch in the NEW memory module with the tab in the memory-module connector.
  4. Dell Inspiron N5010 Memory Modules Replacement, Install the Memory Module: 步骤 5 中的图像 1,1
    • Slide the memory module firmly into the connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
终点
另外一个人完成了本指南。
Terrence15
于12/18/17注册
78,592 声望
创作了441篇指南
团队
Informative Technologies Inc. Informative Technologies Inc. 的会员
Community
38 名成员
创作了1,982篇指南
一条评论
I have dell Inspiron n5010 laptop with 2gb ram(2gb 1R*8 PC3-10600s-09-11-B2).I need to upgrade ram to 8gb.suggest me exact ram which supports my laptop.if you suggest the buying link,it would be more helpful to me.
Babu j Ramaswamy - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 14
总计 563
