跳转到主内容
简介
In this guide, we will be showing you how to remove and replace the Memory Modules.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer)
    • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory module securing clips.
  1. Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the module pops up. Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the module pops up.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the module pops up.
  2. Remove the memory module from the memory-module connector.
    • Remove the memory module from the memory-module connector.
  3. Align the notch in the NEW memory module with the tab in the memory-module connector. Align the notch in the NEW memory module with the tab in the memory-module connector.
    • Align the notch in the NEW memory module with the tab in the memory-module connector.
  4. Slide the memory module firmly into the connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • Slide the memory module firmly into the connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
终点
另外一个人完成了本指南。
Terrence15
于2017年12月18日注册
73,327 信誉积分
创作了442篇指南
团队
Informative Technologies Inc. Informative Technologies Inc. 的会员
Community
38 名成员
创作了1,949篇指南
一条评论
I have dell Inspiron n5010 laptop with 2gb ram(2gb 1R*8 PC3-10600s-09-11-B2).I need to upgrade ram to 8gb.suggest me exact ram which supports my laptop.if you suggest the buying link,it would be more helpful to me.
Babu j Ramaswamy - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 3
总计 380
