跳转到主内容
Dell Inspiron N4110 Screen Replacement
你所需要的
  1. Dell Inspiron N4110 Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the laptop is off and unplugged before starting this step.
    • Locate the battery on the underside of the laptop.
    • Push the two battery clips following the direction of the arrows.
  2. Dell Inspiron N4110 Screen Replacement: 步骤 2 中的图像 1,1
    • Push upward from the base of the battery.
  3. Dell Inspiron N4110 Screen Replacement: 步骤 3 中的图像 1,1
    • Pull battery away from computer until it is fully removed.
  4. Dell Inspiron N4110 Screen Replacement, Screen: 步骤 4 中的图像 1,3 Dell Inspiron N4110 Screen Replacement, Screen: 步骤 4 中的图像 2,3 Dell Inspiron N4110 Screen Replacement, Screen: 步骤 4 中的图像 3,3
    • Use your hands to remove the plastic cover from around the screen.
    • This can seem difficult, but it can be done.
  5. Dell Inspiron N4110 Screen Replacement: 步骤 5 中的图像 1,2 Dell Inspiron N4110 Screen Replacement: 步骤 5 中的图像 2,2
    • Unscrew the two 2.5x4 mm screws from the top of the screen.
  6. Dell Inspiron N4110 Screen Replacement: 步骤 6 中的图像 1,2 Dell Inspiron N4110 Screen Replacement: 步骤 6 中的图像 2,2
    • Loosen the four 2.5x4 mm screws from the base of the screen.
    • This will allow the screen to lift from inside the top of the case.
  7. Dell Inspiron N4110 Screen Replacement: 步骤 7 中的图像 1,3 Dell Inspiron N4110 Screen Replacement: 步骤 7 中的图像 2,3 Dell Inspiron N4110 Screen Replacement: 步骤 7 中的图像 3,3
    • Unscrew the four 2x3 mm screws from the two sides on both the top and bottom.
  8. Dell Inspiron N4110 Screen Replacement: 步骤 8 中的图像 1,2 Dell Inspiron N4110 Screen Replacement: 步骤 8 中的图像 2,2
    • Use tweezers to peel the webcam away from the top of the laptop.
    • The webcam is only held in place by a webcam, this is easy to pull away from the screen.
  9. Dell Inspiron N4110 Screen Replacement: 步骤 9 中的图像 1,3 Dell Inspiron N4110 Screen Replacement: 步骤 9 中的图像 2,3 Dell Inspiron N4110 Screen Replacement: 步骤 9 中的图像 3,3
    • Lift the adhesive flap from the cord that connects the computer to the screen.
    • You can then disconnect the cord from the screen.
  10. Dell Inspiron N4110 Screen Replacement: 步骤 10 中的图像 1,1
    • The screen can now be fully removed from the computer.
结论
另外一个人完成了本指南。
Abigail Keith
于03/20/18注册
505 声望
创作了2篇指南
团队
UMass Dartmouth, Team S5-G1, Peak Spring 2018 UMass Dartmouth, Team S5-G1, Peak Spring 2018 的会员
UMASSD-PEAK-S18S5G1
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 1,201
