跳转到主内容
Dell Inspiron N4110 Motherboard Replacement
你所需要的
  1. Dell Inspiron N4110 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the laptop is off and unplugged before starting this step.
    • Locate the battery on the underside of the laptop.
    • Push the two battery clips following the direction of the arrows.
  2. Dell Inspiron N4110 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Push upward from the base of the battery.
  3. Dell Inspiron N4110 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Pull battery away from computer until it is fully removed.
  4. Dell Inspiron N4110 Motherboard Replacement, Fan: 步骤 4 中的图像 1,2 Dell Inspiron N4110 Motherboard Replacement, Fan: 步骤 4 中的图像 2,2
    • Remove the 10 2.5x5 mm screws from the base of the laptop.
  5. Dell Inspiron N4110 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Unscrew the final 2.5x5 mm screw attached to the cover.
    • This screw is "captive" and does not detach from the cover. Make sure the screw is fully unscrewed before attempting to remove the cover.
  6. Dell Inspiron N4110 Motherboard Replacement: 步骤 6 中的图像 1,2 Dell Inspiron N4110 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Remove the cover from the laptop.
  7. Dell Inspiron N4110 Motherboard Replacement: 步骤 7 中的图像 1,2 Dell Inspiron N4110 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Unscrew the 2.5x5 mm screw inside the RAM compartment.
  8. Dell Inspiron N4110 Motherboard Replacement: 步骤 8 中的图像 1,2 Dell Inspiron N4110 Motherboard Replacement: 步骤 8 中的图像 2,2
    • Remove the disk drive from the side of the computer.
    • There is no need to press the button, the drive will come out.
  9. Dell Inspiron N4110 Motherboard Replacement: 步骤 9 中的图像 1,2 Dell Inspiron N4110 Motherboard Replacement: 步骤 9 中的图像 2,2
    • Unscrew the two 2x3 mm screws inside the disk drive compartment.
  10. Dell Inspiron N4110 Motherboard Replacement: 步骤 10 中的图像 1,3 Dell Inspiron N4110 Motherboard Replacement: 步骤 10 中的图像 2,3 Dell Inspiron N4110 Motherboard Replacement: 步骤 10 中的图像 3,3
    • Flip the computer over, and open the laptop.
    • Use a plastic opening tool to begin to remove the keyboard.
    • Use your hands to finish separating the keyboard from the laptop.
    • This can be a bit challenging, but it will come loose.
  11. Dell Inspiron N4110 Motherboard Replacement: 步骤 11 中的图像 1,1
    • Lift the black clip from the tan connection for the keyboard.
    • Pull the the connection away from the clip.
    • Move the keyboard away from the laptop.
    • With the keyboard removed, consider this opportunity to more freely clean it out with some compressed air.
  12. Dell Inspiron N4110 Motherboard Replacement: 步骤 12 中的图像 1,1
    • Lift the black clips from the tan connections for all 3 locations marked.
    • Remove the connections from the clips.
  13. Dell Inspiron N4110 Motherboard Replacement: 步骤 13 中的图像 1,1
    • Unscrew the five 2.5x5 mm screws.
  14. Dell Inspiron N4110 Motherboard Replacement: 步骤 14 中的图像 1,2 Dell Inspiron N4110 Motherboard Replacement: 步骤 14 中的图像 2,2
    • Use plastic opening tools to remove base cover.
    • Use your hands to fully remove cover from the base.
    • This may be difficult, but it is possible.
  15. Dell Inspiron N4110 Motherboard Replacement: 步骤 15 中的图像 1,1
    • Disconnect the two cables that connect the speaker and the fan.
    • These can just be pulled out, they do not have clips.
  16. Dell Inspiron N4110 Motherboard Replacement: 步骤 16 中的图像 1,1
    • Disconnect the ribbon cable over the screw to reveal it. Flip up the latch and pull gently on the ribbon to remove it from the connector.
    • Unscrew the 2.5x5 mm screw from the fan.
  17. Dell Inspiron N4110 Motherboard Replacement: 步骤 17 中的图像 1,2 Dell Inspiron N4110 Motherboard Replacement: 步骤 17 中的图像 2,2
    • Pull up and remove the fan from the laptop.
  18. Dell Inspiron N4110 Motherboard Replacement, Motherboard: 步骤 18 中的图像 1,1
    • Unscrew the six 2.5x5mm screws from the motherboard.
    • Note that this screw may be "retained" by the loop at the end of the grounding wire.
  19. Dell Inspiron N4110 Motherboard Replacement: 步骤 19 中的图像 1,2 Dell Inspiron N4110 Motherboard Replacement: 步骤 19 中的图像 2,2
    • Disconnect the black and yellow cable from the motherboard.
  20. Dell Inspiron N4110 Motherboard Replacement: 步骤 20 中的图像 1,1
    • Begin to separate the motherboard from the laptop
    • Pull up to separate from the other internal pieces, and then pull to the right away from the case
  21. Dell Inspiron N4110 Motherboard Replacement: 步骤 21 中的图像 1,1
    • Remove the final cable from the motherboard
    • This will allow the motherboard to fully come out of the computer
    • When reinstalling motherboard, ensure the two connectors are precisely aligned with the daughterboard below. If slightly misaligned, you may bend the pins on the daughterboard connector.
结论
2等其他人完成本指南。
Olivia
于03/20/18注册
773 声望
创作了3篇指南
团队
UMass Dartmouth, Team S5-G1, Peak Spring 2018 UMass Dartmouth, Team S5-G1, Peak Spring 2018 的会员
UMASSD-PEAK-S18S5G1
3 名成员
创作了6篇指南
2条评论
After pulling off the battery, the step to remove the four M2x3 mm screws was forgotten. Please update the guide.
apocalypse612 - 回复
Hi my Friend, can you send me a picture in this zone, i need change a transistor smd to controller the battery charged.
The transistor is near to connector display
Sorry for my English, I'm a uruguayan thanks
Agustin - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 42
总计 2,677
