简介
Replacing the screen is a lengthy process that can take a while. It is important you are gentle with the screen as it can be damaged quite easily. Additionally, the screen should be disposed of according to local laws.
  1. Use a plastic opening tool to remove the screen bezel.
    • Use a plastic opening tool to remove the screen bezel.
  2. Using the #0 Philips head, unscrew the screen bracket from the base of the laptop.
    • Using the #0 Philips head, unscrew the screen bracket from the base of the laptop.
    • Remove the plastic seal located on the back of the screen to expose the ribbon connector.
    • Unplug the ribbon cable from the screen.
    • Be careful when unplugging the cable. Make sure you peel the tape all the way back before disconnecting.
    • Use the #0 Philips head to remove the six screws on either sides of the screen frame.
    • Remove the metal frame from the screen.
结论
2等其他人完成本指南。
Jonathan Sellier
于2017年09月26日注册
778 信誉积分
创作了7篇指南
团队
USF Tampa, Team S13-G5, Boczar Fall 2017 USF Tampa, Team S13-G5, Boczar Fall 2017 的会员
USFT-BOCZAR-F17S13G5
5 名成员
创作了9篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 15
总计 267
