跳转到主内容
Dell Inspiron N4010 Memory Modules Replacement
  1. Dell Inspiron N4010 Memory Modules Replacement, Popping up the Memory Module: 步骤 1 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the module pops up.
  2. Dell Inspiron N4010 Memory Modules Replacement, Remove the Memory Module: 步骤 2 中的图像 1,1
    • Remove the memory module from the memory-module connector.
  3. Dell Inspiron N4010 Memory Modules Replacement, Align the Notch: 步骤 3 中的图像 1,1
    • Align the notch in the NEW memory module with the tab in the memory-module connector.
  4. Dell Inspiron N4010 Memory Modules Replacement, Sliding the Memory Module: 步骤 4 中的图像 1,1
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
终点
Terrence15
于12/18/17注册
79,121 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 8
总计 433
