跳转到主内容
Dell Inspiron N4010 Keyboard Replacement
你所需要的
  1. Dell Inspiron N4010 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the laptop is not plugged into any wall outlets or the charger
    • Unlock the battery by sliding the right-hand switch to the right.
  2. Dell Inspiron N4010 Keyboard Replacement: 步骤 2 中的图像 1,2 Dell Inspiron N4010 Keyboard Replacement: 步骤 2 中的图像 2,2
    • While holding the left-hand switch to the left position, pull the battery away from the laptop.
  3. Dell Inspiron N4010 Keyboard Replacement: 步骤 3 中的图像 1,1
    • The battery is now fully removed and the laptop will not power on without it.
  4. Dell Inspiron N4010 Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,3 Dell Inspiron N4010 Keyboard Replacement, Keyboard: 步骤 4 中的图像 2,3 Dell Inspiron N4010 Keyboard Replacement, Keyboard: 步骤 4 中的图像 3,3
    • Using the #0 Philips head, unscrew the indicated screw.
    • Carefully pull the RAM cover up and away.
  5. Dell Inspiron N4010 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Unscrew the indicated 5.7mm screw beneath the RAM Cover.
    • Remove another screw above the battery release tab
  6. Dell Inspiron N4010 Keyboard Replacement: 步骤 7 中的图像 1,2 Dell Inspiron N4010 Keyboard Replacement: 步骤 7 中的图像 2,2
    • Using a thin plastic tool (such as a guitar pick or spudger) at the top of the keyboard just above the F7 key, gently pry the keyboard away.
    • Move the spudger to either end at the top of the keyboard to fully undo all plastic clips.
  7. Dell Inspiron N4010 Keyboard Replacement: 步骤 8 中的图像 1,2 Dell Inspiron N4010 Keyboard Replacement: 步骤 8 中的图像 2,2
    • Carefully tip the keyboard upwards and pull it slightly away from the body of the laptop.
    • Be careful not to put stress on the ribbon cable below.
  8. Dell Inspiron N4010 Keyboard Replacement: 步骤 9 中的图像 1,2 Dell Inspiron N4010 Keyboard Replacement: 步骤 9 中的图像 2,2
    • Carefully unclip the ribbon cable by tipping the keyboard towards the screen.
    • The keyboard is now completely disconnected.
结论
2等其他人完成本指南。
团队
USF Tampa, Team S13-G5, Boczar Fall 2017 USF Tampa, Team S13-G5, Boczar Fall 2017 的会员
USFT-BOCZAR-F17S13G5
5 名成员
创作了9篇指南
一条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 14
总计 988
