跳转到主内容
Dell Inspiron Mini 1012: Keyboard Replacement
你所需要的
  1. Dell Inspiron Mini 1012: Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Remove the battery
  2. Dell Inspiron Mini 1012: Keyboard Replacement: 步骤 2 中的图像 1,1
    • Using a Philip's head screwdriver, remove three screws: one directly below the battery and the other two to the right and the left of the two battery lock switches
  3. Dell Inspiron Mini 1012: Keyboard Replacement: 步骤 3 中的图像 1,2 Dell Inspiron Mini 1012: Keyboard Replacement: 步骤 3 中的图像 2,2
    • At the top of the keyboard, insert the metal spudger between the keyboard's metal frame and the body of the laptop as shown
    • When inserting the metal spudger, be sure to place the spudger under the frame and not under a key to avoid damaging the component
    • Gently lift up the keyboard starting at the top of the frame
    • Make sure that you do not damage the ribbon attached to the bottom of the keyboard
  4. Dell Inspiron Mini 1012: Keyboard Replacement: 步骤 4 中的图像 1,1
    • Pull the clear tab at the end of the ribbon towards the hard drive to detach the ribbon
    • Perform steps one through four in reverse order with your new keyboard to finish the replacement process
终点
4等其他人完成本指南。
Marie K Bordley
于09/30/14注册
241 声望
创作了2篇指南
团队
Ohio State, Team 1-1, Buehl Fall 2014 Ohio State, Team 1-1, Buehl Fall 2014 的会员
OSU-BUEHL-F14S1G1
4 名成员
创作了4篇指南
一条评论
After keyboard open, You can change HDD or Memory as you like.
최희욱 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 3,294
