跳转到主内容
Dell Inspiron Mini 1012 Screen Replacement
你所需要的
  1. Dell Inspiron Mini 1012 Screen Replacement, Screen: 步骤 1 中的图像 1,3 Dell Inspiron Mini 1012 Screen Replacement, Screen: 步骤 1 中的图像 2,3 Dell Inspiron Mini 1012 Screen Replacement, Screen: 步骤 1 中的图像 3,3
    • Remove the battery from the device for safety. Slide the two tabs on the bottom of the computer to the unlocked position, and gently lift up the battery.
    • Remove the two rubber pieces at the bottom of the screen and remove the screws located behind them.
    • Carefully remove the plastic casing from the device.
  2. Dell Inspiron Mini 1012 Screen Replacement: 步骤 2 中的图像 1,3 Dell Inspiron Mini 1012 Screen Replacement: 步骤 2 中的图像 2,3 Dell Inspiron Mini 1012 Screen Replacement: 步骤 2 中的图像 3,3
    • Remove the four screws on each corner of the screen. Then remove the screws located on the side of the screen.
    • Carefully unplug the ribbon on the back of the screen.
  3. Dell Inspiron Mini 1012 Screen Replacement: 步骤 3 中的图像 1,3 Dell Inspiron Mini 1012 Screen Replacement: 步骤 3 中的图像 2,3 Dell Inspiron Mini 1012 Screen Replacement: 步骤 3 中的图像 3,3
    • Place the new screen onto the device and plug the ribbon in.
    • Replace the screws on the side of the screen.
  4. Dell Inspiron Mini 1012 Screen Replacement: 步骤 4 中的图像 1,3 Dell Inspiron Mini 1012 Screen Replacement: 步骤 4 中的图像 2,3 Dell Inspiron Mini 1012 Screen Replacement: 步骤 4 中的图像 3,3
    • Snap on the plastic screen cover and replace the two screws and the rubber pieces at the bottom of the screen.
    • Turn the computer over and put the battery back in.
结论
To reassemble your device, follow guide instructions.
2等其他人完成本指南。
sabinabarajas
于10/17/15注册
372 声望
创作了3篇指南
团队
Gateway, Team 2-2, Kuhn Fall 2015 Gateway, Team 2-2, Kuhn Fall 2015 的会员
GCC-KUHN-F15S2G2
1 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 1,322
