简介
Step by step instructions on how to locate and remove screws and parts of the device to locate the screen, remove it, replace it with a new one, and put the device back together.
你所需要的
Remove the battery from the device for safety. Slide the two tabs on the bottom of the computer to the unlocked position, and gently lift up the battery.
Remove the two rubber pieces at the bottom of the screen and remove the screws located behind them.
Carefully remove the plastic casing from the device.
To reassemble your device, follow guide instructions.
2等其他人完成本指南。
