跳转到主内容
Dell Inspiron Mini 1012 Keyboard Replacement
你所需要的
  1. Dell Inspiron Mini 1012 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,3 Dell Inspiron Mini 1012 Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,3 Dell Inspiron Mini 1012 Keyboard Replacement, Keyboard: 步骤 1 中的图像 3,3
    • Unlock the two tabs on the bottom of the laptop.
    • Use your fingernail or a spudger to pull the battery pack out of the laptop.
  2. Dell Inspiron Mini 1012 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Remove the three screws with a Phillips #00 screwdriver.
  3. Dell Inspiron Mini 1012 Keyboard Replacement: 步骤 3 中的图像 1,2 Dell Inspiron Mini 1012 Keyboard Replacement: 步骤 3 中的图像 2,2
    • Insert the spudger between the top of the keyboard and the laptop body.
    • Carefully pry the keyboard up.
    • Be gentle! You don't want to damage the laptops ribbon cable connector by pulling too hard.
    • It's not recommended to use a metal spudger for this repair as the photo shows. A regular nylon spudger will work just fine.
  4. Dell Inspiron Mini 1012 Keyboard Replacement: 步骤 4 中的图像 1,2 Dell Inspiron Mini 1012 Keyboard Replacement: 步骤 4 中的图像 2,2
    • Unlock the connector to release the ribbon cable.
    • Carefully pull on the clear tab to remove the keyboard from the device.
  5. Dell Inspiron Mini 1012 Keyboard Replacement: 步骤 5 中的图像 1,3 Dell Inspiron Mini 1012 Keyboard Replacement: 步骤 5 中的图像 2,3 Dell Inspiron Mini 1012 Keyboard Replacement: 步骤 5 中的图像 3,3
    • Take the new keyboard and insert the ribbon cable into the connector on the laptop.
    • Lay the keyboard back onto the device and gently snap it back into place.
结论
To reassemble your device, follow these instructions in reverse order starting at step two.
sabinabarajas
于10/17/15注册
372 声望
创作了3篇指南
团队
Gateway, Team 2-2, Kuhn Fall 2015 Gateway, Team 2-2, Kuhn Fall 2015 的会员
GCC-KUHN-F15S2G2
1 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 624
