跳转到主内容
Dell Inspiron Mini 1012 Battery Replacement
  1. Dell Inspiron Mini 1012 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Dell Inspiron Mini 1012 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Dell Inspiron Mini 1012 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Turn the device over so the bottom is facing upwards.
    • Slide the two tabs beside the lock icons to the unlocked position.
    • Find the notch located in the center between the two tabs and lift up on the battery to remove it.
    • To replace the battery, align the three notches on the battery with the grooves on the device. Snap the battery back onto the device, and it will lock in place.
结论
To reassemble, place the new battery in the three slots. Lock the battery back in place.
sabinabarajas
于10/17/15注册
372 声望
创作了3篇指南
团队
Gateway, Team 2-2, Kuhn Fall 2015 Gateway, Team 2-2, Kuhn Fall 2015 的会员
GCC-KUHN-F15S2G2
1 名成员
创作了6篇指南
一条评论
So, I’ve installed the new battery and the mini 1012 won’t recognize or charge it. Now what?
complainingparty - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 14
总计 1,522
