跳转到主内容
Dell Inspiron Mini 10 Touchpad Replacement
你所需要的
  1. Dell Inspiron Mini 10 Touchpad Replacement, Battery: 步骤 1 中的图像 1,1
    • To prevent injury and loss of data, ensure the device is turned off.
    • Slide the release latches out toward the edges to unlock the battery.
  2. Dell Inspiron Mini 10 Touchpad Replacement: 步骤 2 中的图像 1,1
    • Remove the battery by pulling it up and out.
  3. Dell Inspiron Mini 10 Touchpad Replacement, Touchpad: 步骤 3 中的图像 1,2 Dell Inspiron Mini 10 Touchpad Replacement, Touchpad: 步骤 3 中的图像 2,2
    • Using a spudger, gently pry the palm rest off of the palm rest bracket.
    • Carefully remove the palm rest from the computer base to avoid damage to the palm rest.
  4. Dell Inspiron Mini 10 Touchpad Replacement: 步骤 4 中的图像 1,1
    • Gently pull the touchpad cable off the palm rest bracket.
    • Lift the rest of the palm rest off the computer base.
  5. Dell Inspiron Mini 10 Touchpad Replacement: 步骤 5 中的图像 1,3 Dell Inspiron Mini 10 Touchpad Replacement: 步骤 5 中的图像 2,3 Dell Inspiron Mini 10 Touchpad Replacement: 步骤 5 中的图像 3,3
    • Turn the palm rest assembly over.
    • Remove the four 3mm Phillips 0 screws that secure the touchpad module to the palm rest.
    • Gently lift the copper and silver foil squares on the touchpad.
    • Remove the touchpad from the palm rest.
结论
Angela Wild
于10/26/16注册
104 声望
撰写一个指南
团队
UW Tacoma, Team 1-4, Rose Fall 2016 UW Tacoma, Team 1-4, Rose Fall 2016 的会员
UWT-ROSE-F16S1G4
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 619
