简介
This guide will give step-by-step instructions on how to replace the memory card in your device.
你所需要的
On the bottom of the laptop locate the removable panel and screw holding it to the body. Loosen the screw and take the cover off.
在这个步骤中使用的工具:Tweezers$4.99
Remove the black and white antenna cable from the wifi adapter by pinching the gold contacts with the tips of your finger, or you can use tweezers, and pull them straight away from the adapter.
Unscrew the single 5mm Phillips 0 screw on the top right of the adapter. The adapter should start to angle away from the body of the computer. Once the screw is off completely, pull the adapter out of the data slot.
Using a prying tool, gently pry the palm rest off of the palm rest bracket. Start prying from one side and slowly work your way around.
Remove the following:
Two 4mm Phillips screws securing the motherboard
AC adapter cable
USB and SIM card cable connector
Display cable connector
Carefully lift the motherboard out.
3等其他人完成本指南。
4指南评论
It is possible to upgrade the memory by simply (!) cutting aq hole in the bottom of the computer case. I used the pictures and Vulcan logic to determine the location and dimensions of the required hole. I used a vibrating saw to cut the hole. You need to be careful not to cut too deep. Once you have a square panel cut out, you need to snip through the copper shield covering the memory card. Then it is a simple in and out replacement. I used a leftover 2 Gig memory card from my MacBook Pro.
Mucheasier than taking out all those screws and connectors!
Here’s an easier-but riskier- technique. Cut a rectangular hole in the bottom of your Mini 10V. I did it and it worked. Needles to say, you must be careful not to cut too deep! Measure in from the left side (computer shut, upside down and the empty battery compartment away from you) 3/4 inch, and 4.5 inch (from the edge. the lines you draw will be 3.75 inches apart. measure up from the keyboard edge 2.5 inches and 4.75 inches and draw horizontal lines. The ‘box’ you drew is your cutting template. Once inside you need to cut a copper shield to get to the memory card. From that point on it’s easy. I used the 2 gig memory card from my MacBook Pro. When you’re done, glue the panel you cut out back in place and reinsert battery and you’re ready to go. (For cutting the hole, I used a vibrating multi tool with a saw blade)
Disclaimer: Your mileage may vary. If you brick your Mini 10V, you can buy another on Ebay for ~$75.
Good Luck.
Excellent step-by-step graphical explanation makes it look easy by following the instructions congratulations.
Not all Mini 10's have upgradable RAM. When I tore mine down, I found there was nothing of interest on the back of the board where the guide says there's a SODIMM slot. Then again, my board seems to be quite different from the one used in this guide: my wireless module was not accessible from the outside but was found underneath the keyboard; my board did not extend all the way to the SD card slot, as that was a separate board connected to the main board by a ribbon cable; and what looked to be a heatsink covering a SODIMM slot turned out to be a daughter board containing the CPU and the RAM together. Mind you, this guide served its purpose in getting my netbook torn all the way down; it simply didn't serve its final intention. The model number for my Mini 10 is PP19S, which happens to have a very colorful shell on the top. If your model number matches mine, save yourself the trouble: the RAM cannot be upgraded conventionally. Then again, if you're comfortable installing surface-mount RAM... :p
