跳转到主内容
Dell Inspiron Mini 10 Palm Rest Replacement
你所需要的
  1. Dell Inspiron Mini 10 Palm Rest Replacement, Battery: 步骤 1 中的图像 1,1
    • To prevent injury and loss of data, ensure the device is turned off.
    • Slide the release latches out toward the edges to unlock the battery.
  2. Dell Inspiron Mini 10 Palm Rest Replacement: 步骤 2 中的图像 1,1
    • Remove the battery by pulling it up and out.
  3. Dell Inspiron Mini 10 Palm Rest Replacement, Palm Rest: 步骤 3 中的图像 1,1
    • Using a prying tool, gently pry the palm rest off of the palm rest bracket. Start prying from one side and slowly work your way around.
    • Carefully remove the palm rest from the computer base since it is still connected by a cable and to avoid damage to the palm rest.
  4. Dell Inspiron Mini 10 Palm Rest Replacement: 步骤 4 中的图像 1,1
    • Gently pull the touchpad cable off the palm rest bracket.
    • Lift the rest of the palm rest off the computer base.
结论
Bariso Shuba
于10/26/16注册
270 声望
创作了3篇指南
团队
UW Tacoma, Team 1-4, Rose Fall 2016 UW Tacoma, Team 1-4, Rose Fall 2016 的会员
UWT-ROSE-F16S1G4
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 5
总计 395
