跳转到主内容
Dell Inspiron Mini 10 Palm Rest Bracket Replacement
你所需要的
  1. Dell Inspiron Mini 10 Palm Rest Bracket Replacement, Battery: 步骤 1 中的图像 1,1
    • To prevent injury and loss of data, ensure the device is turned off.
    • Slide the release latches out toward the edges to unlock the battery.
  2. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 步骤 2 中的图像 1,1
    • Remove the battery by pulling it up and out.
  3. Dell Inspiron Mini 10 Palm Rest Bracket Replacement, Keyboard: 步骤 3 中的图像 1,1
    • Remove the three 8mm Philips 0 screws securing the keyboard.
  4. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 步骤 4 中的图像 1,1
    • Turn over the device and open the display.
    • Gently pry open the keyboard with the plastic opening tool, working under the edges to release the clips.
  5. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 步骤 5 中的图像 1,2 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 步骤 5 中的图像 2,2
    • Lift the keyboard off of the support bracket carefully since it is still connected by a ribbon cable.
  6. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 步骤 6 中的图像 1,2 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 步骤 6 中的图像 2,2
    • Push the clips out on either side of the ribbon cable to release it.
    • Gently disconnect the ribbon cable by pulling on the clear tab.
    • Remove the keyboard.
  7. Dell Inspiron Mini 10 Palm Rest Bracket Replacement, Palm Rest Bracket: 步骤 7 中的图像 1,1
    • Close the device and turn over.
    • Remove the five 8mm Phillips 0 screws.
  8. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 步骤 8 中的图像 1,2 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 步骤 8 中的图像 2,2
    • Turn the device over and open the display.
    • Remove the single 8mm Phillips 0 screw attaching the hard-drive cage to the body of the device.
  9. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 步骤 9 中的图像 1,2 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 步骤 9 中的图像 2,2
    • Pull on the black tab and slide the hard-drive cage toward the USB port on the left side of the device until its comes free and carefully lift out of device.
  10. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 步骤 10 中的图像 1,2 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 步骤 10 中的图像 2,2
    • Remove the four 6mm Philips 0 screws securing the bracket.
  11. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 步骤 11 中的图像 1,3 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 步骤 11 中的图像 2,3 Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 步骤 11 中的图像 3,3
    • Disconnect the following:
    • Power button cable
    • Speaker cable
    • Power status light cable
    • Bluetooth cable (if installed)
  12. Dell Inspiron Mini 10 Palm Rest Bracket Replacement: 步骤 12 中的图像 1,1
    • Gently pry off the bracket using the prying tool.
结论
团队
UW Tacoma, Team 1-4, Rose Fall 2016 UW Tacoma, Team 1-4, Rose Fall 2016 的会员
UWT-ROSE-F16S1G4
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 12
总计 268
