跳转到主内容
Dell Inspiron Mini 10 Keyboard Replacement
你所需要的
  1. Dell Inspiron Mini 10 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • To prevent injury and loss of data, ensure the device is turned off.
    • Slide the release latches out toward the edges to unlock the battery.
  2. Dell Inspiron Mini 10 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Remove the battery by pulling it up and out.
  3. Dell Inspiron Mini 10 Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,1
    • Remove the three 8mm Philips 0 screws securing the keyboard.
  4. Dell Inspiron Mini 10 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Turn over the device and open the display.
    • Gently pry open the keyboard with the plastic opening tool, working under the edges to release the clips.
  5. Dell Inspiron Mini 10 Keyboard Replacement: 步骤 5 中的图像 1,2 Dell Inspiron Mini 10 Keyboard Replacement: 步骤 5 中的图像 2,2
    • Lift the keyboard off of the support bracket carefully since it is still connected by a ribbon cable.
  6. Dell Inspiron Mini 10 Keyboard Replacement: 步骤 6 中的图像 1,2 Dell Inspiron Mini 10 Keyboard Replacement: 步骤 6 中的图像 2,2
    • Push the clips out on either side of the ribbon cable to release it.
    • Gently disconnect the ribbon cable by pulling on the clear tab.
    • Remove the keyboard.
结论
团队
UW Tacoma, Team 1-4, Rose Fall 2016 UW Tacoma, Team 1-4, Rose Fall 2016 的会员
UWT-ROSE-F16S1G4
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 1,333
