跳转到主内容
Dell Inspiron Mini 10 Display Panel Replacement
你所需要的
  1. Dell Inspiron Mini 10 Display Panel Replacement, Battery: 步骤 1 中的图像 1,1
    • To prevent injury and loss of data, ensure the device is turned off.
    • Slide the release latches out toward the edges to unlock the battery.
  2. Dell Inspiron Mini 10 Display Panel Replacement: 步骤 2 中的图像 1,1
    • Remove the battery by pulling it up and out.
  3. Dell Inspiron Mini 10 Display Panel Replacement, Palm Rest: 步骤 3 中的图像 1,1
    • Using a prying tool, gently pry the palm rest off of the palm rest bracket. Start prying from one side and slowly work your way around.
    • Carefully remove the palm rest from the computer base since it is still connected by a cable and to avoid damage to the palm rest.
  4. Dell Inspiron Mini 10 Display Panel Replacement: 步骤 4 中的图像 1,1
    • Gently pull the touchpad cable off the palm rest bracket.
    • Lift the rest of the palm rest off the computer base.
  5. Dell Inspiron Mini 10 Display Panel Replacement, Keyboard: 步骤 5 中的图像 1,1
    • Remove the three 8mm Philips 0 screws securing the keyboard.
  6. Dell Inspiron Mini 10 Display Panel Replacement: 步骤 6 中的图像 1,1
    • Turn over the device and open the display.
    • Gently pry open the keyboard with the plastic opening tool, working under the edges to release the clips.
  7. Dell Inspiron Mini 10 Display Panel Replacement: 步骤 7 中的图像 1,2 Dell Inspiron Mini 10 Display Panel Replacement: 步骤 7 中的图像 2,2
    • Lift the keyboard off of the support bracket carefully since it is still connected by a ribbon cable.
  8. Dell Inspiron Mini 10 Display Panel Replacement: 步骤 8 中的图像 1,2 Dell Inspiron Mini 10 Display Panel Replacement: 步骤 8 中的图像 2,2
    • Push the clips out on either side of the ribbon cable to release it.
    • Gently disconnect the ribbon cable by pulling on the clear tab.
    • Remove the keyboard.
  9. Dell Inspiron Mini 10 Display Panel Replacement, Palm Rest Bracket: 步骤 9 中的图像 1,1
    • Close the device and turn over.
    • Remove the five 8mm Phillips 0 screws.
  10. Dell Inspiron Mini 10 Display Panel Replacement: 步骤 10 中的图像 1,2 Dell Inspiron Mini 10 Display Panel Replacement: 步骤 10 中的图像 2,2
    • Turn the device over and open the display.
    • Remove the single 8mm Phillips 0 screw attaching the hard-drive cage to the body of the device.
  11. Dell Inspiron Mini 10 Display Panel Replacement: 步骤 11 中的图像 1,2 Dell Inspiron Mini 10 Display Panel Replacement: 步骤 11 中的图像 2,2
    • Pull on the black tab and slide the hard-drive cage toward the USB port on the left side of the device until its comes free and carefully lift out of device.
  12. Dell Inspiron Mini 10 Display Panel Replacement: 步骤 12 中的图像 1,2 Dell Inspiron Mini 10 Display Panel Replacement: 步骤 12 中的图像 2,2
    • Remove the four 6mm Philips 0 screws securing the bracket.
  13. Dell Inspiron Mini 10 Display Panel Replacement: 步骤 13 中的图像 1,3 Dell Inspiron Mini 10 Display Panel Replacement: 步骤 13 中的图像 2,3 Dell Inspiron Mini 10 Display Panel Replacement: 步骤 13 中的图像 3,3
    • Disconnect the following:
    • Power button cable
    • Speaker cable
    • Power status light cable
    • Bluetooth cable (if installed)
  14. Dell Inspiron Mini 10 Display Panel Replacement: 步骤 14 中的图像 1,1
    • Gently pry off the bracket using the prying tool.
  15. Dell Inspiron Mini 10 Display Panel Replacement, Motherboard: 步骤 15 中的图像 1,1
    • Remove the following:
    • Two 4mm Phillips screws securing the motherboard
    • AC adapter cable
    • USB and SIM card cable connector
    • Display cable connector
    • Carefully lift the motherboard out.
  16. Dell Inspiron Mini 10 Display Panel Replacement, Display Panel: 步骤 16 中的图像 1,2 Dell Inspiron Mini 10 Display Panel Replacement, Display Panel: 步骤 16 中的图像 2,2
    • Pull the Mini-Card cables out of the computer base. They slide out from under a few pieces of plastic that secure them to the base.
  17. Dell Inspiron Mini 10 Display Panel Replacement: 步骤 17 中的图像 1,2 Dell Inspiron Mini 10 Display Panel Replacement: 步骤 17 中的图像 2,2
    • Remove the two 4 mm Phillips 0 screws that secure the display assembly to the computer base.
  18. Dell Inspiron Mini 10 Display Panel Replacement: 步骤 18 中的图像 1,1
    • Lift and remove the display assembly from the computer base.
  19. Dell Inspiron Mini 10 Display Panel Replacement: 步骤 19 中的图像 1,1
    • Press and remove the hinge cover caps using the spudger.
  20. Dell Inspiron Mini 10 Display Panel Replacement: 步骤 20 中的图像 1,1
    • Remove the two rubber pads on the display bezel screws using a finger nail, prying tool or Spudger.
    • There is one on either side.
  21. Dell Inspiron Mini 10 Display Panel Replacement: 步骤 21 中的图像 1,2 Dell Inspiron Mini 10 Display Panel Replacement: 步骤 21 中的图像 2,2
    • Remove the two 4 mm Phillips 0 screws on the display bezel.
  22. Dell Inspiron Mini 10 Display Panel Replacement: 步骤 22 中的图像 1,1
    • Using the plastic opening tool gently pry up the inside edge of the display bezel.
  23. Dell Inspiron Mini 10 Display Panel Replacement: 步骤 23 中的图像 1,1
    • Remove the display bezel using a plastic prying tool.
  24. Dell Inspiron Mini 10 Display Panel Replacement: 步骤 24 中的图像 1,2 Dell Inspiron Mini 10 Display Panel Replacement: 步骤 24 中的图像 2,2
    • Remove the single 3mm Phillips screw securing the camera to the display panel.
  25. Dell Inspiron Mini 10 Display Panel Replacement: 步骤 25 中的图像 1,3 Dell Inspiron Mini 10 Display Panel Replacement: 步骤 25 中的图像 2,3 Dell Inspiron Mini 10 Display Panel Replacement: 步骤 25 中的图像 3,3
    • Remove the two 4mm Phillips 0 screws that are visible from the top.
    • Remove the four 3mm Phillips screws on the side of the display panel securing it to the display cover.
  26. Dell Inspiron Mini 10 Display Panel Replacement: 步骤 26 中的图像 1,1
    • Remove the display panel.
    • The display panel is fragile, handle with care.
  27. Dell Inspiron Mini 10 Display Panel Replacement: 步骤 27 中的图像 1,1
    在这个步骤中使用的工具:
    • Disconnect the camera cable using tweezers.
  28. Dell Inspiron Mini 10 Display Panel Replacement: 步骤 28 中的图像 1,1
    • Remove the panel connector by pulling on the blue tab on the back of the display panel.
结论
另外一个人完成了本指南。
团队
UW Tacoma, Team 1-4, Rose Fall 2016 UW Tacoma, Team 1-4, Rose Fall 2016 的会员
UWT-ROSE-F16S1G4
4 名成员
创作了10篇指南
1指南评论
What model it's the camera
Andrew Andras - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 16
总计 1,435
