跳转到主内容
Dell Inspiron M5110 Palmrest Replacement
你所需要的
  1. Dell Inspiron M5110 Palmrest Replacement, Battery: 步骤 1 中的图像 1,1
    • Shut down the computer and turn it upside down.
  2. Dell Inspiron M5110 Palmrest Replacement: 步骤 2 中的图像 1,1
    • Slide both of the battery release latches on the bottom of the device in towards the center of the computer.
  3. Dell Inspiron M5110 Palmrest Replacement: 步骤 3 中的图像 1,1
    • Slide and lift the battery up and out from the device.
  4. Dell Inspiron M5110 Palmrest Replacement, Keyboard: 步骤 4 中的图像 1,1
    • Open the computer and push the screen back as far as possible.
  5. Dell Inspiron M5110 Palmrest Replacement: 步骤 5 中的图像 1,1
    • Slide a plastic opening tool into the slots on the top of the keyboard.
  6. Dell Inspiron M5110 Palmrest Replacement: 步骤 6 中的图像 1,1
    • Pry the keyboard away from the device using the plastic opening tool.
  7. Dell Inspiron M5110 Palmrest Replacement: 步骤 7 中的图像 1,1
    • Lift and slide the keyboard towards the screen to remove the tabs on the keyboard from the slots on the palmrest.
  8. Dell Inspiron M5110 Palmrest Replacement: 步骤 8 中的图像 1,1
    • Flip the keyboard over and place it on the front of the device making sure not to pull out the keyboard cable.
  9. Dell Inspiron M5110 Palmrest Replacement: 步骤 9 中的图像 1,1
    • Lift up the connector latch and remove the keyboard cable. The keyboard is now free from the device.
  10. Dell Inspiron M5110 Palmrest Replacement, Palmrest: 步骤 10 中的图像 1,1
    • Turn the computer over and remove the six screws that secure the palmrest assembly
  11. Dell Inspiron M5110 Palmrest Replacement: 步骤 11 中的图像 1,1
    • Turn the computer over and open the display as far as possible and remove the four 5 mm Phillips # 0 screw holding the palmrest in place.
  12. Dell Inspiron M5110 Palmrest Replacement: 步骤 12 中的图像 1,2 Dell Inspiron M5110 Palmrest Replacement: 步骤 12 中的图像 2,2
    • Disconnect the power button board cable, touch pad cable and the hot key board cable from the connectors.
  13. Dell Inspiron M5110 Palmrest Replacement: 步骤 13 中的图像 1,2 Dell Inspiron M5110 Palmrest Replacement: 步骤 13 中的图像 2,2
    • Use a plastic opening tool to carefully pry out the palmrest assembly and lift it off the computer base.
结论
另外一个人完成了本指南。
Larain
于10/26/16注册
387 声望
创作了3篇指南
团队
UMass Dartmouth, Team 4-3, Catania Fall 2016 UMass Dartmouth, Team 4-3, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S4G3
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 182
