跳转到主内容
Dell Inspiron M5030 Keyboard Replacement
你所需要的
  1. Dell Inspiron M5030 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,2 Dell Inspiron M5030 Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Remove all fourteen Phillips #0 7/16" screws from the bottom of the laptop.
    • Remove the two Phillips #0 5/16" screws from the bottom of the laptop.
  2. Dell Inspiron M5030 Keyboard Replacement: 步骤 2 中的图像 1,2 Dell Inspiron M5030 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Turn the laptop over and open the lid.
    • Locate the three tabs above the first row of keys on the top of the keyboard, found above the F1, F6, and PrntScr keys.
    • With one of your hands, push the leftmost tab down with the plastic opening tool (above the F1 key). With your other hand, lift the left side of the keyboard.
    • Push the middle tab down with the plastic opening tool and continue lifting from the left side of the keyboard to the right side (above the F6 key).
    • Push the rightmost tab down with the plastic opening tool and continue lifting from the left side of the keyboard to the right side (above the PrntScr key). The keyboard should be loosened from the laptop after these steps.
  3. Dell Inspiron M5030 Keyboard Replacement: 步骤 3 中的图像 1,2 Dell Inspiron M5030 Keyboard Replacement: 步骤 3 中的图像 2,2
    • After the top edge of the keyboard is loose, pull up on the keyboard gently.
    • Do not pull the keyboard up forcefully as the keyboard is still attached to the laptop by a ribbon.
  4. Dell Inspiron M5030 Keyboard Replacement: 步骤 4 中的图像 1,3 Dell Inspiron M5030 Keyboard Replacement: 步骤 4 中的图像 2,3 Dell Inspiron M5030 Keyboard Replacement: 步骤 4 中的图像 3,3
    • Pull up the bottom side of the keyboard and locate the ribbon connecting the keyboard to the motherboard.
    • Locate the blue end of the ribbon which is connected to the motherboard.
    • Lift up the black flap on the connector and gently pull the ribbon away from the connector which is parallel to the motherboard.
    • Lift the keyboard up and off of the motherboard. Detach the blue end of the ribbon from the connector.
结论
4等其他人完成本指南。
Ryan Moelter
于04/17/14注册
382 声望
创作了2篇指南
团队
Cal Poly, Team 3-44, Maness Spring 2014 Cal Poly, Team 3-44, Maness Spring 2014 的会员
CPSU-MANESS-S14S3G44
4 名成员
创作了6篇指南
2条评论
Do you know any ways to replace 4 keys Spacebar,B,N and the Slash/Question Mark are broken plz help
Snapchat Hotdog - 回复
The keyboard is best handled as a whole part replacement. You can find M5030 replacement keyboards for about $10 on Amazon/eBay.
Robert Johnson -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 20
总计 1,363
