当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Use a spudger to remove the six rubber nibs and 2 plastic pieces on the bezel of the display.
Remove the eight Phillips #0 screws hidden under the rubber nibs and plastic pieces.
Pry the plastic bezel from the back plate using a plastic opening tool.
Remove the plastic bezel entirely and set it aside.
Remove the 4 screws along the left and right sides of the screen. There are 8 screws in total.
Use the spudger to separate the screen from the back case.
Hold the screen in one hand and tilt the back case away from you.
The screen is connected to the back case by two leads.
Remove the two leads from the screen. They will stay connected to the computer.
Do not touch the white tape on your replacement monitor.
Remove the screen carefully.
取消:我没有完成这个指南。
9等其他人完成本指南。
与8其他贡献者
于10/05/10注册
613 声望
创作了4篇指南
徽章: 13
+ 10更多徽章
CPSU-MANESS-F10S22G5
4 名成员
创作了11篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 6,995
