跳转到主内容
Dell Inspiron E1705 Upper Case and Screen Replacement
你所需要的
  1. Dell Inspiron E1705 Upper Case and Screen Replacement, Upper Case and Screen: 步骤 1 中的图像 1,1
    • Use a spudger to remove the six rubber nibs and 2 plastic pieces on the bezel of the display.
    • Remove the eight Phillips #0 screws hidden under the rubber nibs and plastic pieces.
  2. Dell Inspiron E1705 Upper Case and Screen Replacement: 步骤 2 中的图像 1,2 Dell Inspiron E1705 Upper Case and Screen Replacement: 步骤 2 中的图像 2,2
    • Pry the plastic bezel from the back plate using a plastic opening tool.
    • Remove the plastic bezel entirely and set it aside.
  3. Dell Inspiron E1705 Upper Case and Screen Replacement: 步骤 3 中的图像 1,2 Dell Inspiron E1705 Upper Case and Screen Replacement: 步骤 3 中的图像 2,2
    • Remove the 4 screws along the left and right sides of the screen. There are 8 screws in total.
  4. Dell Inspiron E1705 Upper Case and Screen Replacement: 步骤 4 中的图像 1,2 Dell Inspiron E1705 Upper Case and Screen Replacement: 步骤 4 中的图像 2,2
    • Use the spudger to separate the screen from the back case.
    • Hold the screen in one hand and tilt the back case away from you.
    • The screen is connected to the back case by two leads.
  5. Dell Inspiron E1705 Upper Case and Screen Replacement: 步骤 5 中的图像 1,2 Dell Inspiron E1705 Upper Case and Screen Replacement: 步骤 5 中的图像 2,2
    • Remove the two leads from the screen. They will stay connected to the computer.
    • Do not touch the white tape on your replacement monitor.
    • Remove the screen carefully.
结论
9等其他人完成本指南。
Evan Fairchild
于10/05/10注册
613 声望
创作了4篇指南
团队
Cal Poly, Team 22-5, Maness Fall 2010 Cal Poly, Team 22-5, Maness Fall 2010 的会员
CPSU-MANESS-F10S22G5
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 19
总计 7,015
